vortec heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2012, 07:53 PM
vortec heads
need help chosing plugs nothing is realy popping out as a good choice autolites run good but didnt last that long ngks arnt realy handling the fuel from the 750 that well and ac delcos realy didnt last neither any body think they can help?
Old 03-11-2012, 07:27 AM
bondo's Avatar
Ayuh,... I run AC Delco MR43TLS in my boats, 'n they're run darn near Forever....
The automotive plugs, just drop the M,.. which means the marine plugs are an alloy body....
Btw,.... No sparkplug in the world will Fix a Carb Problem....
If yer fouling plugs, it's Over-fueling....Aka; a Carb Problem...
Old 03-11-2012, 09:12 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
As part of your tune, you need to get the heat range right as well, that's probably what's eating plugs.
Semper Fi
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-18-2013 11:00 PM
dart heads vs vortec heads repeat Engine 48 03-10-2012 08:05 PM
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 03:17 PM
Will a intake off vortec heads fit non-vortec heads nobody_1250 Engine 13 12-27-2010 05:02 AM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
