Vortec heads
Can someone help me with my vortec motor has roller can or not??? Its in an 82 Chevy truck I recently bought...it now has Carb. An electric fuel pump...."no boss/hole on block" so how can I tell if its roller or not????
Remove valve cover, loosen rocker, remove a push rod and measure it. Standard flat tappet pushrods are 7.794". If they are shorter then you have a roller. Keep in mind retro-rollers use a shorter than OE roller pushrod.
While you are in there with the vavle covers off. Check the cylinder head casting number. I bet they are not vortec heads and you don;t got a vortec motor.
I bet itsa older TBI motor with TBI swirl port heads. L-31 Vortec heads have a casting number ending in 906 or 062. |
| Summit Racing vortec heads VS GM Performance Vortec heads | jsm1847 | Engine | 4 | 05-29-2012 06:01 PM |
| putting 305 vortec heads on an pre-vortec 350 | thor1022 | Engine | 11 | 01-12-2011 03:17 PM |
| Will a intake off vortec heads fit non-vortec heads | nobody_1250 | Engine | 13 | 12-27-2010 05:02 AM |
| 305 vortec heads vs 350 vortec | rimracers | Engine | 6 | 04-02-2007 08:41 PM |
| Vortec heads or 1971 487x LT1 heads? | speedfrk3 | Engine | 2 | 10-07-2002 04:12 PM |
