Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - vortec heads on a 406, can it be done on pump gas?
Old 09-01-2008, 11:24 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
You may pull it off then if you followed the guidelines I said. However, I would get more opinions from others in here that may have already did the same combo.
