With a tight quench, timing slightly on the low side, a slightly rich mixture, and coolant temps in the 180 degree range you might pull it off, but I wouldn`t hold my breath, especially if it has the stock 5.565 rod lenth.
In many cases, and this arguement has went on and on, it doesn`t detonate in the low rpm ranges so the driver thinks it don`t in the upper rpm ranges, but they don`t understand, the cam is bleeding off a lot of the cylinder pressure during low rpm use, then there isn`t the time for it to in the upper rpm ranges, so the engine could be detonating and due to the noise of the engine, exhaust and etc. It`s very difficult to hear. By the time it`s figured out the engine is usually gone. |
it's a 5.7 rod motor & the pistons i'm useing are sealed power L2489F.
how did people get by with double hump heads? i've seen plenty of flat top 406's with double hump heads. i've used 67cc heads before without any issues, but i figured it up at 11.52 with 64cc heads. |
You may pull it off then if you followed the guidelines I said. However, I would get more opinions from others in here that may have already did the same combo.
There is no practical difference between iron and aluminum for heat dispersion. Dyno tests prove it. A few milliseconds is just not enough time for heat to transfer. MOST of the heat goes out the exhaust.
Remember roller cams lose 8* due to lash. Keep that LSA down to 106*. .040-.050 squish distance is critical. Soft-edge everything in the chamber/piston. Timing curve will be critical as will mixture control. Water injection is a good idea. I ran an 11/1 '70 350/350 on 91-93 with water injection. Vortec heads are better. You could also take some meat out of the chambers. I suggest looking into the "head grooving" threads on this forum. It works. Automotivebreath is the "expert". Remember the higher the rpm, the less "clock time" for detonation to occur. Good luck, be prepared to buy race fuel. Enginequest makes replacement Vortec heads in different sizes. Check that. Last edited by ScoTFrenzel; 09-01-2008 at 12:31 PM. |
How did people run double hump heads on 400's? Their 64cc chambers & need a lot more timing. I've seen several over the years with flat tops & double hump heads & run on 93 pump gas. what's the difference?
just so everyone knows. i already have the vortec heads. their not costing me a cent other than springs & having guides machined. that is the only reason i want to use them. FWIW, i took the exhaust valves out to check the seats to make sure their not the one's with the big seat that restricts flow & their not. Last edited by 406 ss monte; 09-13-2008 at 08:08 PM. |
Here is a similar link with some good info.
http://speedtalk.com/forum/viewtopic.php?t=12353 |
that would be me too.
i'm about ready to pull the 406 short block, & put in the factory vortec short block & use with the vortec heads. i would hate to screw up my 406 pistons from detonation. the 350 would be better suited with the heads anyways
| Lt1 heads on vortec block | Ugly89Camaro | Engine | 3 | 01-14-2008 09:53 PM |
| Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? | zeeman19 | Engine | 7 | 02-13-2007 03:17 PM |
| Motorheads...Need help with Vortec style heads, can they just be swapped? | firstgear | Engine | 16 | 01-15-2007 12:02 AM |
| vortec vs phase 2 heads | 71vegagt | Engine | 3 | 01-29-2006 05:12 AM |
| Which waterpump? | Eagle1 | Engine | 5 | 08-06-2004 06:38 PM |
