vortec heads and compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2002, 05:09 PM
Red face vortec heads and compression
I am in the process of rebuilding my 350 and have come to the question of heads. I am really interested in the aftermarket Vortec heads by GM. The problem I'm having is that with the pistons I put in, the manufacturer says I should get 9.39:1 compression with the 64cc chambers. I am just wondering if this is too much to run regular pump fuel in my motor. I have an Edelbrock cam (.420 Int & .442 Exh), Edelbrock performer intake and an Edelbrock 600 cfm carb. I keep getting varying opinions about this and any good suggestions would be much appreciated. <img src="confused.gif" border="0">
Old 12-17-2002, 05:37 PM
DoubleVision's Avatar
Post
on 93 octane pump gas you should be fine, if in any doubt, you can run a thicker head gasket to lower to compression slightly, but I wouldn`t do so unless I had to.
Old 12-17-2002, 06:07 PM
F-1Rodder's Avatar
Post
It depends on how much overlap you will have in your cam, more will reduce the compression. Also the elevation you will be running at, the higher is better. However, I am at sea level and run 10.3:1 with a mid level cam and do not have problem on high octane pump. Do not compensate by putting a fat head gasket in there. You want a real tight quench area so that you can dissallow detonation.
