vortec heads cracking? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2012, 07:41 AM
Hi, just going to fit my vortec heads(906) ready for the new season,have been reading that they are prone to cracking! Do they crack in a certain place? if so where do I need to look, if they are can I weld them up and what rods do I need to use?,thanks in advance Dave
Old 02-24-2012, 04:51 PM
BOBCRMAN@aol.com's Avatar
These heads usually crack from the center exhaust seats to the nearest cooling crossover or center head bolt hole. Minor head bolt hole cracking can be fixed by drilling and reaming the hole oversize (usually 5/8") past the end of crack, about 1 1/8" deep. Then pressing a repair locktite coated sleeve ( I use a farm tractor cast iron guide) into the oversized hole. Then drill the ID. of the sleeve to std bolt hole size. Trim length. Mill head. Never had a return.
Seat cracks cannot be welded by a novice. The insert type seats, if equipped, must be removed. Heads heated to red hot in a kiln. Welded while red and very slowly cooled. Then heads cut for inserts and seats cut. Finally chambers shaped and heads milled flat.
Lots of labor and cheaper to buy aftermkt heads..
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
chevy327 (01-13-2013)
Old 02-25-2012, 11:15 AM
i bought 3 sets of factory vortec heads all cracked.i am done with then. so i went and bought a set of rhs heads. i made some good numbers with my setup on the dyno with rhs heads
Old 02-25-2012, 12:02 PM
Thanks for the info guys,will get them magnafluxed,cant believe so many are cracked! Wont bother buying an intake manifold until theyre checked,we pay a lot over here(uk) for vortec intakes oh well,thanks for replies!
Old 02-26-2012, 08:21 AM
I definitely wouldn't buy an intake until you have them checked, I've been junkyarding 4 times over the past 2 weeks trying to find 1 good head to finish a set. In all I'm out a couple tanks of gas, 10hrs of my life and about 125 dollars in heads for the 3 bad ones I've picked up.
Old 02-26-2012, 02:44 PM
yes mate,I know what you mean,if these are cracked I will go with a set of aluminium heads,and save some weight!
Old 01-13-2013, 09:33 PM
vortec head crack location
would some one here show me the picture where the crack on vortec head,because i had set vortec casting 906,but i dont know how to find the crack on these head,thanks
Old 01-13-2013, 09:36 PM
wuold you tell me how to find crack on my vortec head
Old 01-13-2013, 09:39 PM
would some one here show me the picture where the crack on vortec crack because i had set #906,i want find crack before i install on my block thanks
Old 01-13-2013, 10:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Red lines show where to look for the more common cracks (this is an end chamber, you're much more likely to find the center chambers cracked). I have no info on them cracking between the valves on the center chambers because they lack a heat crossover like the earlier heads, but I'd still check there.
Best bet is to haul them in to the machine shop and have them checked. You need to know if they're flat or not, and you should CC the chambers so you know what the compression ratio will be.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 01-13-2013, 11:09 PM
thank i will take them to mechine shop for sure,did you know how much it cost to check crack
Old 01-14-2013, 08:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Ballpark $50-$75 should get you a thorough inspection including deck flatness. I would clean it real well before taking them in, or plan to have them tank or cook them before inspecting. Hopefully that'll be deducted from the cost to rebuild them if you have them done at the same shop.
There are good machinists here (BOBCRMAN has posted to this thread already) that can tell you what they do, I'm going by what my shop does and that might not be what they all do.
Old 01-14-2013, 09:04 AM
Banned
they are 299.oo new,, with valves and springs..
I'd not even look in a j/y
Old 01-14-2013, 09:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
$299 new, per head. A short page on the Vortec head is here.
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-18-2013 11:00 PM
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 03:17 PM
Will a intake off vortec heads fit non-vortec heads nobody_1250 Engine 13 12-27-2010 05:02 AM
Vortecs heads are known for cracking?? doughboyman66 Engine 10 11-29-2009 08:51 PM
Paint cracking...now I'm cracking! gwstang Body - Exterior 24 12-30-2005 08:32 AM
