Vortec heads on Gen 1 SBC, what else is hidden? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2006, 04:27 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
I want to put a set of vortec heads on a 1975 engine. I know you need new intake and rockers and valve covers.
But Im not sure if I need new:
1. head (lenght) bolts?
2. new (lenght) pushrods?
3. can I use standard head/intake gaskets designed for gen 1?
4. vortec head have accesory holes correct, I heard that stock alternator braket wont work with certain manifolds?
anything else?
Old 11-11-2006, 05:02 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Its a true bolt-on, but I personally never re-use head bolts. For not much money you can get new ARP bolts.
Pushrods same
head gasket same
intake gasket different. not only is the bolt pattern different, but the vortec has slightly raised ports.
exhaust gasket same
Vortec heads will have accessory bolt holes. I've heard rumors of race vortec heads that didn't, but I doubt you have the rumor heads . I used a GM bowtie intake on my build and it did come with the bolt hole for the alternator. If yours doesn't, it should be easy to fab a bracket that goes to one of the intake bolts.
Old 11-11-2006, 09:23 PM
Warrant's Avatar
K, awesome.
Can I also use the rubber O ring valve seals for a Gen 1 head on the vortec?
And same spark plugs? or do I need shorter lenght ones?
Thanks!
Old 11-12-2006, 07:19 AM
NorthStar's Avatar
Accessory brackets have different bolt spacing than your old heads but now you can run a serpentine belt set up.
Spark plugs are different, threads are longer.
Can still use the o-rings.
Old 11-12-2006, 09:30 AM
firestone's Avatar
http://teamrfc.gospelcom.net
I have used this head gasket is several Vortec headded motors, and it has worked great.
http://store.summitracing.com/partde...t=NAL-10105117
Old 11-12-2006, 02:16 PM
Warrant's Avatar
? I thought Ive seen many vortec heads using old style brackets(power steering, the alternator) it was just that I heard the upper alternator bracket had problems with the bolt hole on manifold
Looking at the remote mount turbo will my vortec heads get the job done leemoses Engine 14 10-06-2010 06:51 AM
SBC Heads -= AFR - Trickflow - Dart - Brodix =- Delirious2000 Engine 25 04-22-2009 12:58 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
SBC Heads interchange JasonKyle Engine 5 05-06-2006 08:08 PM
Holley fuel injection with Vortec heads onna SBC. Pappy Engine 3 06-06-2002 11:17 AM
