Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vortec heads with high left capabilities
Old 08-30-2005, 06:11 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Vortec heads will take .500" lift No Problem with-out machining. It can be done for about $50 including the valve springs!!! Just take the inner dampener from stander 1.26" od valve springs {Z-28 or Edelbrocks} and remove the posi lock valve seals from the heads. replace the seals with Chrysler 2.2 valve seals from a turbo car and you are done!
The porting you can do easily if you have a steady hand, the Vortecs need little from the factory, just a basic clean-up to make good power!
