Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vortec heads with high left capabilities
Old 09-22-2005, 07:41 PM
blazin47's Avatar
blazin47 blazin47 is offline
Blazin Low
I recently bought a set of 062's from Ebay. I stripped them down, bought new +.100 valves, hand lapped them in, a tool tool that Comp makes to cut the seal boss to take a .530 teflon seal, ( their height is lower) , 600 lift springs and ended up at 1.830 installed height. I then changed the locks to -.030 to bring the height down to 1.800 which gives me a .650 max lift. I'm not sure whether to put in screw in studs or just pin them like we use to do. this is my first do it your self valve job!. I guess it should work.
