I wouldn't go TBI
![]() Edelbrock carbs tend to be notoriously lean from the factory. I would look there first, especially because you mentioned that richening it helped some. I might also (depending on the cam) try to get the initial timing up out of the basement. More like 10-14 initial is more in the range of most combos. |
the saga continues
I advanced the timing to 8° and it ran wonderfully for about 15 minutes, then it started to start to sputter and cough. I continued to run it and it started to hiccup? burp out of the carb. From the cabin it almost sounds like an exhaust leak. Once I took of the air cleaner I could see that I was getting some back discharge up through the carb.
To make sure I did this right, when I timed it, the mark on the balancer was below the timing marks, I reset the dizzy/timing so it came up past the marks to 8°. Is this correct? I advanced it right? any help as always appreciated. |
You have the timing Retarded 8*. |
Timing and carb looked fine.
I pulled of the right side valve cover and the #7 exhaust rocker was off of the valve. I spun the engine around until I knew that it had opened and closed and the same of the intake, tightened it up to zero lash plus 1/2 turn. Started it up and could still here some rattling. I checked and now the intake on #7 was loose.....Tightened it up to zero lash plus half a turn. Going to bed now, to tired to dick with it anymore. I have a set of arm ball and nuts for the rocker arms, not very impressed with them. I have already had a few rockers come loose. Are poly's any better? |
If you reuse the original self-locking nuts, expect them to back off. Even though they will sometimes work OK with only one on-off-on sequence, it's just not worth it IMO. They only cost a couple bucks. |
Vortecs require self aligning rockers, don't they? Are you using self aligning rockers?
Also, No one has asked if this is a new cam. Almost sounds like number seven lobes are going away. JA |
Thanks for the replies
It is not a new cam, I kept the older one in there. The rocker arm nuts I speak of I got through summit, Here I'll see how she goes today! |
weird that it would work its way off. |
Good luck! |
| vortec heads?? | Streetnova | Engine | 8 | 04-04-2007 09:33 AM |
| vortec vs phase 2 heads | 71vegagt | Engine | 3 | 01-29-2006 05:12 AM |
| 383-- use the vortec heads? what cam? | slonova | Engine | 10 | 02-02-2004 11:45 AM |
| Vortec Heads / Max Lift? | onecoomofo | Engine | 16 | 01-27-2004 11:51 AM |
| vortec heads on a 87 z28 block? | molevolent_creations | Engine | 1 | 12-04-2003 10:54 PM |
