Vortec heads Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2008, 03:59 PM
chewyscool's Avatar
Big Block 454
Its time to bolt on some heads to my motor build.
327 .30 over
stock flat tops
comp xe256h cam
I want GMPP vortec heads but what is the max lift for these heads?
I've read here and jegs and summit all different information, just will I be alright with the cam that I have installed?
Shoud I get alm. heads from eddy being that I will be near 10:1 compression?
And will an eddy performer head be equal to their etec? ( if i go alm.)
This motor will be used as a cruiser not track.
Thanks for any advice
Old 07-14-2008, 04:06 PM
scapegoat's Avatar
The run of the mill vortec heads that jegs/summit sells will handle .475 lift. You could look into an RDS pro torker vortec head. The accept either style intake and usually have heavier springs.
http://www.speedwaymotors.com/p/6613...der-Heads.html
Old 07-14-2008, 07:48 PM
Scoggin-Dickey sells brand new Vortec heads modified for higher valve lift, and some that are also machined for screw-in rocker studs.
www.sdparts.com , click on engine parts, cylinder heads, SDPC Vortec heads
A flat-top 327 with 64cc heads only has ~9.6:1 CR, GM just rounded it off to 10:1 so it sounded better.
Old 07-14-2008, 08:30 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
You will be fine with stock vortecs with your cam. If you have a vortec style manifold already and want aluminum heads, the Etecs are hard to beat. Superior cathedral style ports mean excellent velocity of the air/fuel mixture. There is a reason that the LS1, LS2, and LS7 engines utilize that style port.
You could also go with the GM Bowtie Vortec heads. 180 cc or 200 cc intake volumes. Can handle much more lift than your cam presently has and you will have room to add more cam in the future. Comparable in price to aluminum edelbrock heads. Do you want cast iron or aluminum heads? Either of these heads will work great. With your cam right now, anything other than stock vortecs would definitely be overkill.
Old 07-14-2008, 10:28 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
327 .30 over
stock flat tops
comp xe256h cam
General Motors says the lift limit on GM 12558060 heads is 0.0450". You may see some clearance between the retainer and seal at this lift, but remember, you MUST have some clearance at full lift.
Old 07-17-2008, 12:41 AM
Xero420's Avatar
The Camaro Kidd
Last journal entry: Vortec heads
Comp. Cams makes a spring kit that will put it to 0.550 in. on stock heads.
Old 07-17-2008, 10:08 AM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
I'm running these on my vette, and they're a hard deal to beat... Produce excellent power. Just make sure you set your quench properly.
Old 07-18-2008, 05:05 PM
Xero420's Avatar
The Camaro Kidd
I put a set on my 350 with flat tops and got 9:5.1. But I want to up my compression, so I am having the heads re-angled by .5 degree. The shop I have all my work done at told me that I will gain 12 to 14cc for this. But he warned me about the quench.
So what is the quench, and what do I need to look for?
Old 07-19-2008, 08:23 PM
acr acr is offline
Google-"cylinder head quench", then go to the KB-Silvolite Home page for a definition/explanation.
Old 08-11-2008, 08:34 PM
These springs have pretty much solved the vortec lift limit. Bee Hive Springs
Old 08-11-2008, 10:31 PM
DENCOUCH's Avatar
A lot to be said for Vortec heads & basic GM parts
There are others cams out there for Vortec heads that don't require any special lift consideration & work well with the stock lift limits.
F-Bird'88 recommends using basic Z28 springs (Cheap-less than $50) for serious Vortec heads. Stock springs are sissy stuff when it comes to open pressures.
The Vortec head comes alive with 45 thou shaved off and bolted back onto the block with a 15 thou Felpro steel shim gasket. Block needs to be flat tho, max 3 thou warp per 6 inches.
All this stuff will give you a great quench using flat top pistons, and work like a dream if you try one of the "Lift Rules" camshafts that Isky has out.
The duration is crazy and the lobe centerline is small, but the new high compression is NP on pump gas!
The initial timing is set at a crazy 26 degrees. Ported Vacuum advance instead of manifold.
Torque monster... tromp the gas & the tires light up. Motor howls and revs with a sense of urgency.
All this HP with little machining or expensive parts.
Priceless!
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
What are the pros and cons of Vortec heads? Slimpikins Engine 13 02-06-2006 02:17 PM
5.7 Vortec Heads Mustangsaly Engine 4 12-09-2005 07:48 PM
vortec heads on sbc 400 camino_man Engine 16 11-11-2005 01:33 AM
1997 350 Vortec Questions bobfray Engine 6 11-28-2003 01:15 PM
