Vortec Heads, and standard intake. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2010, 09:44 PM
MrPhotographer06's Avatar
Krazy Kid
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
Is there anyway possible to put vortec heads on, and use a standard intake?
I've heard you can re drill the degree of the intake and the bolt holes will work?
or is it best while spending money to go with the vortec style intake?
Thanks,
Scott
Old 04-22-2010, 09:50 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Using a Vortec-specific intake manifold is the only way to get the ports to line up properly and seal with the gasket. Of course you can make anything fit anything if you have enough determination, but that doesn't make it right.
Old 04-22-2010, 09:51 PM
ericnova72's Avatar
More for Less Racer
The head can be drilled and tapped for the old pattern but the material is thin in the area of the new holes and this thin-ness leaves only a few threads in the holes making them prone to stripping easily. There is also an issue with the taller shape of the Vortec intake port and some older intakes are not tall enough to properly cover the port allowing an instant vacuum leak, or a possibilty of one.
The correct Vortec bolt pattern intake is a much better idea all around.
There are aftermarket Vortec-port style heads with both bolt patterns but they are cast thick enough for the thread stripping to not be an issue, although the port hieght can still be an issue depending on the old intake used.
Krazy Kid
eh, alright, alright..
I'll spend the extra money. maybe craigslist will have something.
Its helped me out alot so far.
Old 04-23-2010, 12:01 PM
Stick it out and wait on one , I bought a Performer RPM used for $85 bucks.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Motorheads...Need help with Vortec style heads, can they just be swapped? firstgear Engine 16 01-15-2007 12:02 AM
Vortec heads and standard SBC Intake Question ComingApart Engine 16 05-11-2006 03:09 PM
Head recommendation - low HP w/LT1 intake Tim240Z Engine 0 07-08-2004 12:56 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
