Vortec heads vs old style - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2012, 09:28 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
A decent read.I approve of this link:
A Guide to Vortec vs OE Small Block Chevy Heads | OneDirt
Old 12-01-2012, 09:53 PM
vinniekq2's Avatar
1Gary,what was the part number (292)? of the G M service cast heads with angle plugs,very popular and cheap in early 80s?
Old 12-01-2012, 09:55 PM
1Gary's Avatar
The link doesn't speak about adjust the push rod length when cutting down heads or the common machine work Vortec's need,but you guys know about that already.
Old 12-02-2012, 12:19 AM
1Gary's Avatar
Sorry Vinnie.I don't understand.Thought there was a error in the link and went back to check.I couldn't find it.
Old 12-02-2012, 12:32 AM
vinniekq2's Avatar
1Gary,I did not see the heads I used back in the early 80s. GM cast iron,2.02,angle plug heads sold as service heads over the counter.I thought the castings had 292 in there somewhere. thought you might know the casting number?
My 67 Camaro 355 street car ran 11.9s with those heads @ 114 mph. That was decent back then
Old 12-02-2012, 05:07 AM
SSedan64's Avatar
This it Vinnie? >> 340 292
The Following User Says Thank You to SSedan64 For This Useful Post:
vinniekq2 (12-02-2012)
Old 12-02-2012, 09:54 AM
vinniekq2's Avatar
those are the heads,thank you.They were really cheap too.crane didnt sell them cheap
Old 12-02-2012, 10:11 AM
hcompton's Avatar
Old & Furious
Well only two types of vortec are any good the 906/l31 and the bowtie aftermarket race only heads.
Humps still make more power once they are ported right. Vortecs can only Get mild port work cause they are so thin. Cut them to thin they will crack.
Difference is only a few puppies in stock form.
Now if were talking about after market race heads that need specail intake you can get high ports or 18degree heads that will blow any stock head away.
Vortec = hype not hp. The fact still remains that all vortec heads need machine work to make power. They do not make 400 hp with stock springs and spring pockets. Unless its on a much larger engine than 350.
Just an fyi to all owners with humps you can make the same port mods that give vortecs power. Just need to angle the ports a little to improve flow around the valves. Spark plug position is not talked about in that article but has a lot to do with the vortec magic. And this cant be easily fixed in the humps. But is not a killer in making power if the engine is tunned right.
Old 12-02-2012, 03:16 PM
spinn's Avatar
The vortec heads do work nice on a daily driven vehicle. You could not get the same benefits from a 46x or 601 casting. Even if you tried to copy the modifications on the vortecs. On lifts from .3-400" the vortec are superior. If you were racing you would like to open up the heads a little more. There are some good vortec recipes for a mild driver out there. They are good at flowing while maintaining velocity at lower rpm. Chamber shape , bowl, guide, runner shape, intake entry angle, are good. Nothing bad about the vortecs performance. Sure there are better, but are you going to need that.
My build is with 906 vortecs milled .040" series 2 V6 beehives and retainers. It works very well and cost under $300 for the pair. That includes heads , beehive springs, small retainers, self algining rockers, and all. When the aftermarket can touch that let me know, because any good head at that performance level is over a grand.
Old 12-02-2012, 07:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Couple questions:
What's wrong w/using the other production Vortec head, c/n 062?
Why do you think the small and large port Bow Tie Vortec heads are "race only", or did I misunderstand you?
Old 12-02-2012, 07:54 PM
hcompton's Avatar
Old & Furious
Originally Posted by cobalt327 View Post
Couple questions:
906 and 062 are same head. The bowtie heads are from gm performance group and come as after market heads. They are designed for class racing.
They can be used on the street if you know what your buying.
Old 12-02-2012, 08:10 PM
hcompton's Avatar
Old & Furious
Look like they stop selling the bow ties for the bow tie 2
12480034
They still sell the 906 and the Fuelie heads but dont see the small and large bow ties for sale.
Old 12-02-2012, 10:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Summit, etc. still has the sm/lg port Vortec bow ties.
Old 12-02-2012, 10:53 PM
1Gary's Avatar
GMpartsdirect still listed them as being available.
Old 12-03-2012, 12:02 PM
Banned
Are you comparing fully ported humps to stock Vortecs? Fully ported the Vortecs will still dominate fully ported humps- and you can't make humps into Vortec heads without extensive welding.
Summit Racing vortec heads VS GM Performance Vortec heads jsm1847 Engine 3 05-29-2012 06:01 PM
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 03:17 PM
Will a intake off vortec heads fit non-vortec heads nobody_1250 Engine 13 12-27-2010 05:02 AM
305 vortec heads vs 350 vortec rimracers Engine 6 04-02-2007 08:41 PM
Motorheads...Need help with Vortec style heads, can they just be swapped? firstgear Engine 16 01-15-2007 12:02 AM
