Vortec intake question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2005, 05:50 PM
I bought one of the performance products performer style intakes to go with my new vortec heads. My mechanic said the engine would run very rough because the intake has no provisions for coolant to flow under the carb. This intake is a replica of the Edelbrock Performer and it does not have the coolant crossover either. The Edelbrock Performer RPM and the GM Bowtie intakes both have the coolant crossover ports. My mechanic said you need the coolant to warm the fuel at start up. I just wanted to know what style intake you guys run and is not having the coolant crossover going to be a problem?
Old 12-16-2005, 06:03 PM
My company makes the style manifold that you have. We have sold thousands of them and have never heard a complaint. In fact, it is one of our most popular manifolds.
Old 12-16-2005, 06:10 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
I think your guy is smoking something there is no coolant running under the carb. On some engines theres a exhaust passage. but thats not one of them.
Old 12-16-2005, 06:33 PM
97Z28's Avatar
NTI Grad.
i agree with Deuce, thats some good stuff that guys on. Why would you want to heat the fuel?? wouldnt it be more likely to perculate or vapor lock?
Old 12-16-2005, 07:19 PM
intake
I purchased a Jon Barrett crate motor- he uses the same intake. I haven't started it yet, but I have no doubt it will run well. Jon Barrett has been building motors way too long to damage his reputation now. Bill
Old 12-17-2005, 06:03 AM
FEDDO's Avatar
intake
I would question the capabilities of your mech. Chev has not had a intake with water running under the carb. He is thinking,or not ,of the exhaust. I run a edel air gap with my v tech heads and it works fine.
Old 12-17-2005, 06:24 AM
Bumpstick's Avatar
Hammer and a torch
I agree also that your Mechanic might be thinking of something else...? (exhaust as in EGR...?) GM did have an adapter for 89-90 model 1 ton trucks with 454`s and TBI that had water going through it but not in the manifold itself (under the TBI unit)... Most all performance apps try to keep that area under the carb as cool as possible (hence the air-gap type mainfolds) Unless your in extremely cold conditions where ice could build up on the throttle valves then you would simply use a heat stove system off the exhaust manifold or headers... (directs warm air directly into the carb)
Old 12-17-2005, 06:32 AM
NorthStar's Avatar
5.7 tbi engines had coolant under the throttle body area so he could be getting confused thinking about those.
Old 12-19-2005, 10:04 AM
I thought the same thing. That's the only setup I know of that runs coolant into the middle of the manifold. Although I think the original poster probably misunderstood the mechanic and mixed up a water passage with the exhaust crossover. The heat riser is really only required for cold starts in extremely cold climates.
Old 12-19-2005, 11:45 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Vortec motors and heads do not have the exhaust crossover passages like older engines, the GM Performance Parts Vortec manifolds have a water passage that runs under the plenum for cold weather and marine applications to warm the air fuel mixture to prevent puddling on the plenum floor. For the guys that don't drive their cars in the cold and those that live in warmer climates it's not necessary or even wanted. Something to consider if you drive your carbureted Vortec head small block in the crap we're experiencing right now though, 3 Deg. above! BBBBRRRRRR!!!!!!!!! Blocked heat crossovers, aluminum intakes and sub-freezing temps are not a fun combination.
Old 12-19-2005, 04:36 PM
Water heated Vortec Manifold
You are correct about GM Performance offering a manifold with a water jacket under the plenum. It is G.M. part number 12366573. It appears similar in design to a Professional Products Typhoon or an Edelbrock Performer RPM. GM also makes a Vortec manifold that is similar to a Professinal Products Cyclone or an Edelbrock Performer but it does not have the water jacket in it.
Other than this G.M. manifold, none of the aftermarket Vortec manifolds have a water jacket. However, unless the original person posting the question is planning on operating the vehicle in very cold weather, this is not important. Once the engine reaches operating temperature, the water in the manifold is not needed. In fact, this water jacket in the G.M. manifold would seem to be superflous because when you first attempt to start the car, the water would be cold and would have no value in warming up the intake charge. It would take quite a while for the water to get hot enough to where it would do any good and by that time the engine is warmed up anyway. The old style exhaust heated heat risers provided instant heat. So I am really not sure what function this water jacket performs.
Old 12-19-2005, 07:25 PM
Hippie's Avatar
Originally Posted by jimdavis
You Once the engine reaches operating temperature, the water in the manifold is not needed. In fact, this water jacket in the G.M. manifold would seem to be superflous because when you first attempt to start the car, the water would be cold and would have no value in warming up the intake charge. It would take quite a while for the water to get hot enough to where it would do any good and by that time the engine is warmed up anyway. The old style exhaust heated heat risers provided instant heat. So I am really not sure what function this water jacket performs.
Yeah that had me puzzled too. ?????
Vortec heads and standard SBC Intake Question ComingApart Engine 16 05-11-2006 03:09 PM
pcv/ intake question sfd771 Engine 4 07-19-2004 08:50 AM
Cheap intake for vortec heads? Mike_82 Engine 2 10-23-2003 10:39 PM
Vortec intake change... Bumpstick Engine 1 10-05-2003 07:24 AM
Vortec Intake Manifold Detent Bracket? jvenice Transmission - Rearend 3 12-01-2002 02:07 PM
