vortec lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2005, 09:15 PM
vortec lift
im trying to pick a cam for my vortec headed small block. Iwas wondering fi .420 lift is the absolute max lift with the stock springs i can run. Iwas wanting run one of the new lunati voodoo cams with these heads in stock form, the car is going to be daily driven.
Old 08-29-2005, 09:20 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
.480 is the max. I verified that question through G.M. when I bought my vortec heads a few yrs ago.
Old 08-29-2005, 09:59 PM
Thank you for your reply, i've done numberous research since buying the heads, only to find that most people were very conservative. I pulled the springs off and checked them and came up with clearence for around .480, but was doubting my abilities for 1 second.
Old 08-29-2005, 11:05 PM
lluciano77's Avatar
If you do run .480" check for coil bind once the cam is installed. It only takes a few more minutes and it is cheap insurance.
Old 08-29-2005, 11:43 PM
yeah .480 is the standardized max. as mentioned, check coil bind. and if you want to run a bigger cam than .480 then you can have a machine shop do a little cutting to make it work for you. i think there are a few online shops that sell them ready for .520 lift
NEW GMPP VORTEC heads !! terror385 Engine 1 07-11-2004 09:48 AM
Vortec Heads / Max Lift? onecoomofo Engine 16 01-27-2004 11:51 AM
Vortec heads and High Valve Lift Question TurboS10 Engine 4 03-05-2003 02:16 PM
Vortec heads maximum valve lift? laitch Engine 3 01-26-2003 10:02 AM
Stock Vortec Lift Limit? JohnBoy355 Engine 3 12-05-2002 05:43 PM
