Vortec on old block?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2002, 05:24 PM
Last journal entry: Doors
Post Vortec on old block??
Im thinking about installing vortec heads on my car. I am basically going for low end tourqe and good effiency and economy. The one's i am thinking about getting are 64'cc and 1.94 valves. I already have an edelborke s-p-2-p economy manifold. Would these heads give me good low end tourqe and good economy?? The block is a sbc 350, 72' vette block. And i will be putting it into my 69 firebird with a 700 R4 tranny with 3.18 rear end. Also id have to modify my intake by drilling out the holes and putting in spaced washers in. ALso will i lose alot buy not having the exhaust gas go under the intake with the vortec heads. I will also be using headers with daul exhaust.
Thanks for any advice it is really apprecaited
Old 08-28-2002, 05:47 PM
Post
I'm not faliliar with that manifold but are you sure it will fit the vortec heads. The vortec heads only have 4 bolt holes.
I'm putting a set of vortecs on an '82 350, which I had to buy a designated intake to fit. As far as fitting the older block I think they would fit. I'm not sure if chev. changed the blocks much.
Old 08-29-2002, 07:05 AM
Post
The Vortec heads should bolt onto the older block, however you will have to get a different intake as that intake will not work with the Vortec heads. You need to get a Vortec compatible intake.
Old 08-29-2002, 09:09 AM
Post
I just purchased an intake for $168.00 from Scoggin Dickey. The intake is an Edlebrock Performer RPM I was told it only comes in a square bore style for the Vortec heads.
Old 08-29-2002, 10:04 AM
Post
But, the manifold that i want to use is from the 80's it is a high tourqe good econmy mainifold which they dont make anymore since everyone moved up to TBI injection. Is there away i can that that old manifold to fit??
Old 08-29-2002, 12:34 PM
Post
Sorry, it won't fit. You can use a TBI head and oblong the two center holes. But the tbi heads aren't as good as the vortec. If you want to use your manifold you might want to seek out some double hump 2.02 heads.
Old 08-29-2002, 04:22 PM
72 chevy's Avatar
Post
So, is the head bolt pattern the same for all years of 350 blocks, and vortecs fit em all?? <img src="confused.gif" border="0">
Old 08-30-2002, 07:07 AM
Post
I'm pretty sure they are, but don't take my word for it, it may depend on how old the block is. I'm not sure when GM changed the blocks if they ever did.
Old 08-30-2002, 12:59 PM
Stinkin_V8's Avatar
Suburbanite Member
Post
I saw online somewhere where a guy welded an extension on the sides of a "standard" intake and re-worked the port sizes and bolt holes to use the Vortec heads. Now this was a 4.3L, not a 5.7L, but from what I understand, the fitting problems are the same. It was a Syclone/Typhoon page somewhere but I can't remember much more. I remember seeing a note that some guys change the location of the studs on the Vortec heads and then use a spacer plate under the intake. Sounds like a lot of work to me, way out of my league..
When life hands you lemons, ask for tequila and salt
Old 08-31-2002, 12:45 PM
Talking
[quote]Originally posted by 72 chevy:
[QB][/QB]<hr></blockquote>
I have a catalog from Jim Pace Chevrolet 1-888-748-4675. They have brand new Vortec small block Chevrolet heads that are modiflied to accept the older style intake manifolds......price $510 a pair.
Old 08-31-2002, 10:07 PM
Post
I have one of those sp2p 4bbl intakes. The passages are so small I decided not to use it on my 283! Probably would be ok if you never plan on seeing 5000 but the 350 will have plenty torque even with bigger passages.
Did you look into the cam/intake pachages such as Edelbrock performer?
Old 09-03-2002, 12:33 PM
bullheimer's Avatar
NEVER use credit cards!
Post
FRom what ive read the non vortec intake will work if you elongate the holes that go in vertically instead of at an angle in the center 2 positions so no biggie
Old 09-03-2002, 08:20 PM
MI2600's Avatar
Member# 3287
Post
You can elongate the center manifold holes all you want to, but there are no holes in the heads! I would suggest going with a Vortec intake rather than cobbling up a good manifold. By the time you buy a set of old camelbacks you'll probably have $300-$400 invested. The Edelbrock intakes, either Performer or Performer RPM, are less than $200.
Old 10-11-2002, 09:33 PM
Post
Really want to use them heads and intake comb?? Yes it can be done. Take the heads and intake to a machine shop, have them cut the bolt holes for the intake. Get the older style gasket set and there you go. How do I know?? It's what I race with. Vortec Heads, Marine Bowtie Intake, Rochester two barrel.
Old 10-12-2002, 10:27 PM
Post
And how much does it cost getting the bolt holes cut for the intake compared to the price of an intake?
