Vortec question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2005, 08:09 AM
Vortec question
I have a '98 Chevy vortec motor. How can I determine if this motor is internally or externally balanced?
Old 05-19-2005, 08:15 AM
coldknock's Avatar
Is the engine a 350, 4.3L V6 or a big block?
Also, if the flywheel and/or harmonic damper has a counterweight(flywheel) or a recessed area on the backside(damper) it's externally balanced. Some engines had a combination of both. GM got really screwy with the small block before they finally killed it.
Larry
Old 05-19-2005, 08:30 AM
The engine is a 350 but did not have a flexplate or flywheel when I purchased it. I bought the motor minus intake, distributor, and flexplate a couple of months ago and am getting ready to put it back together. I will check the harmonic damper today.
Old 05-19-2005, 11:46 AM
DoubleVision's Avatar
It`s a half n half, to put it another way, the front of the crank is internally balanced, the rear is externally balanced. When chevy went to a 1 piece rear main seal, the crank flange was made perfectly round and no where to put the counterweight needed to fully internally balance it, so the balance had to be added to the flexplate. When you place it back together and your using the same balancer, make sure the trigger ring is behind it, if the trigger ring on the crank was removed the balancer will be further back on the crank snout and the crank pully won`t line up with the rest.
Old 05-20-2005, 09:19 AM
Thanks guys. This board has been great in getting answers to questions. Since I am an old fart but new to this game its great to find a place where people are more than willing to share info.
vortec head question metalmulisha3x Hotrodding Basics 2 09-17-2004 12:22 AM
Chevy Vortec 350 Truck question 79 Malibu327 Engine 3 07-08-2004 11:41 PM
Vortec head header question 85CHEVY Engine 7 09-07-2003 11:05 PM
Vortec heads and High Valve Lift Question TurboS10 Engine 4 03-05-2003 03:16 PM
a question about vortec 454s notmrgoodwrench Engine 4 02-23-2003 09:02 AM
