vortec roller cam help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2008, 04:06 PM
I am building a 96 vortec block with LT4 Hot cam. I put the timing gear on and it is extremely close to bolt holding cam retainer in, about 030 distance from each other. Is this normal or do I have wrong timing set?
fj
Old 03-30-2008, 04:18 PM
GMC boogie's Avatar
As long as you have clearance,your good to go. I would check and make sure the chain is not rubbing the center oil galley. This is common on late model blocks and double roller sets.
Slight grinding/clearancing at the top of the center oil galley is usually needed.
Old 03-30-2008, 04:52 PM
DoubleVision's Avatar
Just as GMC Boogie pointed out. double roller sets commonly make contact on vortec blocks, this is why Cloyes sells the Vortec street roller timing set. I already seen what a double will do on a Vortec block and seen it ruin a engine.
Old 03-31-2008, 12:04 PM
OK I bought the cloyes street roller for vortec. Now I can't get crank gear to go on all the way. Any hints?
Thanks
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
roller cam retro fit DARIN ALLMAN Engine 14 12-17-2007 05:29 PM
Anything special to put roller cam in 400 block? sb72elcamino350 Engine 1 04-10-2004 12:12 AM
383-- use the vortec heads? what cam? slonova Engine 10 02-02-2004 12:45 PM
Roller Cam Help!!! Vsanthos Engine 13 10-31-2002 05:29 PM
