Vortec TBI ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2012, 09:15 PM
41'srfun's Avatar
Last journal entry: 41' finally has paint on it
Vortec TBI ?
I'm thinking about putting Throttle Body injection on a small block Chevy engine that has Vortec heads with a carb type intake. I can make an adapter to make the throttle body fit the intake with no problem.
My question is do I need an EGR valve to make the computer function properly, or will it work without it.
I can get an intake that has provisions for an EGR, but the intake made for that application is pretty pricey and my budgit is limited, or else I would buy an aftermarket EFI. I already have everything to make it TBI except the proper intake.
Old 10-10-2012, 10:48 PM
Wiki Edits: 31
You can save time and buy a Holley TBI adapter, or the adapter for a TBI 454 engine. EGR can be tuned out. You just need an oxygen sensor and a MAP sensor and it will work
350 TBI to 350 TBI VORTEC SWAP IWANTMOREHP Engine 8 10-20-2016 10:57 AM
Vortec Vs. TBI Heads 1972RedNeck Engine 3 02-06-2011 09:57 PM
TBI vs Vortec Block zildjian4life218 Engine 11 01-26-2010 02:48 PM
TBI vortec problems 11secmudtrk Engine 3 12-14-2004 10:20 PM
Vortec TBI Setup Blebass Engine 1 10-27-2002 07:41 PM
