vortec tunnel ram - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-20-2012, 07:25 PM
vortec tunnel ram
I have a new 1996 GM 5.7 vortec engine with automatic tranny(purchased for a chevy truck). The engine is complete with TBI system including all sensers and computer. I am installing this engine in a 34 chevy street rod with a 1987 Z28 Borg Warner 5 speed. I would like the engine to look "old school" with a tunnel ram dual four setup. I have a couple issues. #1 how to get 80's dual four barrel intake to fit "vortec" heads and #2 does new flywheel require "internal" or external" balance
Old 02-20-2012, 07:50 PM
Wiki Edits: 31
If the engine has a TBI, it is a 1987-1995 engine, and a tunnel ram will fit those heads with a little mod, but it will be so far of a mismatch it wont be funny.. Best bet is to get some decent 64cc heads, camshaft that will operate at about 2,500 RPM+, dual holleys on the tunnel ram and it will run decent.
Recent Modern Electronic Engines posts with photos
Tunnel ram Kendall03 Engine 8 02-07-2011 07:33 AM
Tunnel Ram on 283 58lincoln General Rodding Tech 26 01-20-2009 05:43 PM
Tunnel Ram 327 1970CamARo(327) Engine 57 09-16-2008 08:24 AM
Tunnel ram with Vortec heads ? xxllmm4 Engine 6 09-27-2007 05:00 PM
TUNNEL RAM SET-UP rooster Engine 2 02-19-2003 01:08 PM
