Votec heads stud mod. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2009, 07:16 PM
Just wondering if I use a Comp Cam 268H on a vortec heads should the studs be pinned or tapped for scew in studs?
Old 02-15-2009, 07:33 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
What springs are you planning on using?
Old 02-15-2009, 07:37 PM
DoubleVision's Avatar
Nope, the press in studs will work just fine.
Old 02-15-2009, 08:44 PM
i agree with doublevision. press in is fine. my last car had a 510/533 lift cam with press in studs, no problems, though i was probably pushing it. you don't need anymore than 110 lbs seat pressure for that cam
Old 02-15-2009, 09:07 PM
RE studs
Looking at using the comp cam behives or crane 10309-1 spring kit
Old 02-15-2009, 09:24 PM
beehive is the way to go. my opinion
Old 02-15-2009, 11:38 PM
Senior Curmudgeon
Wiki Edits: 326
Times two.
Old 02-16-2009, 04:34 AM
You won`t need super springs to run that cam. All I would do is the same as I always do, order the springs that match the cam. When you have it all together make sure you use the correct break in oil as if you don`t the cam will go flat.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 10:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
