Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - VSS to cable speedo on 700R4
Old 06-13-2011, 11:05 AM
adantessr's Avatar
adantessr adantessr is offline
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by Thumpin455
I found this page in my searches, it has a chart to figure out what gears you need. Just so happens the ones I need are hardest to find.
http://www.transmissioncenter.net/sp...n_______va.htm
Summit has some of the gears, the hard part is finding the housing.
The seller has responded to say that it depends on the drive gear. That is a good site that you posted. I believe I can figure this out now. The housings that the seller that I posted the link to has plastic housings for $19.95 , or you can pay $72.00 for the aluminum ones. I am going to go pull a tail shaft housing.
