VSS connection - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2008, 05:12 PM
motoxracer's Avatar
VSS connection
Hi got a 2008 ford ranger with he 2.3L 5 speed auto I guess in 1999 ford got rid of the speed sensor in the trans and put it in with the ABS module I need to know where it is located and what color wire to tap into to get the VSS signal Thanks Jeff
Redneck-rigged VSS wiring question for 700R4 Mad Maggot Transmission - Rearend 1 02-21-2006 08:49 AM
4L60E VS 4T60E VSS rotational speed difference 36scsc Transmission - Rearend 2 02-13-2005 03:17 PM
Vss Problem NAIRB Transmission - Rearend 5 01-11-2005 08:20 AM
Need Help With Vss Problem 99 Chevy Pu NAIRB Engine 12 01-09-2005 06:33 PM
Turbo350 Bell crank connection 71Nova Transmission - Rearend 4 11-25-2004 09:21 PM
