-   -   VSS Distaster (http://www.hotrodders.com/forum/vss-distaster-231901.html)
Chevyfan16 04-16-2013 11:06 AM
VSS Distaster
1 Attachment(s)
I just rebuilt my 87 700r4 and am now looking for a speed sensor. I thought it would be as easy as running down to NAPA but nope, no one has ANY! I uploaded a picture of the sensor type I need. Hopefully someone can help me out somehow. The gears dont matter because I have an autometer speedo that I can calibrate. Thank you!
Chevyfan16 04-16-2013 02:59 PM
Never mind...I found a different style that will fit I just had to remove the aluminum sleeve that was stuck in my case!!
Fang16 04-29-2013 09:18 PM
Try this: Dell Search Results
or search for 700r4 vss.
Kawabuggy 04-30-2013 11:11 AM
Check O'Reilly auto parts for part # ABS102. That will be the sensor that you need.
