VSS Distaster - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2013, 11:06 AM
VSS Distaster
I just rebuilt my 87 700r4 and am now looking for a speed sensor. I thought it would be as easy as running down to NAPA but nope, no one has ANY! I uploaded a picture of the sensor type I need. Hopefully someone can help me out somehow. The gears dont matter because I have an autometer speedo that I can calibrate. Thank you!
Old 04-16-2013, 02:59 PM
Never mind...I found a different style that will fit I just had to remove the aluminum sleeve that was stuck in my case!!
Old 04-29-2013, 09:18 PM
Fang16's Avatar
Last journal entry: Project change
Try this: Dell Search Results
or search for 700r4 vss.
Old 04-30-2013, 11:11 AM
Check O'Reilly auto parts for part # ABS102. That will be the sensor that you need.
Painless VSS? 47 Coupe Electrical 2 09-21-2009 05:44 PM
vss placement frank88chevy Transmission - Rearend 4 06-27-2008 06:28 PM
VSS connection motoxracer Electrical 0 03-04-2008 05:12 PM
vss chevys65 Transmission - Rearend 4 02-26-2007 08:25 PM
Vortec Vss zeker6 Engine 0 04-27-2004 01:02 PM
