vss placement - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2008, 02:38 AM
vss placement
on a turbo 400 chevy trans is there a place for a vss so tbi can be used?
Old 06-27-2008, 08:32 AM
Nope. You'll need one of the aftermarket units that goes on the speedo drive gear.
What is this going into? Some 1980s vehicles actually had the VSS built into the spedometer head. The speedo used a normal cable drive and incorporated a light chopper wheel that triggered the VSS optically. Most 1980s GMs with the computer controlled carbs used this setup.
Old 06-27-2008, 08:41 AM
31 five window
Last journal entry: grill and rear end
They make one that goes where your speedo cable goes. You remove your cable and install the VSS then your cable hooks up to the other side of the VSS. I installed one in a 57 Chevy for a cruise control unit.
Old 06-27-2008, 10:45 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
JTR
I used one of these on my TPI pickup with a 700r4.
Old 06-27-2008, 06:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the late t-400 used a reluctor wheel on the out put shaft and the VSS installed into the hole for the speed-O bullet.
Redneck-rigged VSS wiring question for 700R4 Mad Maggot Transmission - Rearend 1 02-21-2006 08:49 AM
4L60E VS 4T60E VSS rotational speed difference 36scsc Transmission - Rearend 2 02-13-2005 03:17 PM
Vss Problem NAIRB Transmission - Rearend 5 01-11-2005 08:20 AM
Need Help With Vss Problem 99 Chevy Pu NAIRB Engine 12 01-09-2005 06:33 PM
Vortec Vss zeker6 Engine 0 04-27-2004 01:02 PM
