VW bug Shell + Jeep Grand Cherokee Frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2012, 03:28 PM
Ok i have a jeep grand Cherokee frame (which Im not lowering or slamming to the ground) and a VW bug shell. Im cutting the front off the Bug and putting the engine there. I would like to keep the trans that is in the jeep in the car, but the engine is toast. I think it'd be cool to also keep the 4 wheel drive. Id really like some help with the engine for i cant figure out if i can use something bigger with this trany. Or if you could give me some tips on what size and type of engine & trans to use thatd be very helpful. Im limited on money and Im a highschool senior. Thank you.
Old 01-05-2012, 07:29 PM
Wiki Edits: 31
Just a suggestion, buy a tape measure and compare the shell to the frame.
Old 01-05-2012, 08:25 PM
What engine is in the Jeep now?
A Wrangler or CJ frame is probably closer to the VW's wheel base.
Old 01-06-2012, 02:42 PM
I know the frame is going to be bigger than the bug. But whats the fun in building something without problems. Im going to cut the fenders off the bug and maybe cut the bug in half if i have to and make it wider. im still in the deconstruction of the jeep tho so maybe ill find a different shell or frame.
Old 01-06-2012, 02:45 PM
It has the straight 6, 4.0 liter. but its fuel injected. all i need for it to run is a new Cap and Rotor and wires. This engine is just temporary tell i find a 350 small block.
And i was just given the jeep so i figured id try it and see if i can pull everything together. but thank you maybe ill see if i can find a wrangler ot the CJ.
Old 01-06-2012, 02:47 PM
[QUOTE=BoomBox] I would like to keep the trans that is in the jeep in the car, but the engine is toast.QUOTE]
Enginge is not toast talked to the old owner and he said he was fixing it. Just needs Cap, Rotor and wires.
05 Grand Cherokee Jeep Noisy Rear End No More.... wuncbitten Transmission - Rearend 19 12-27-2011 06:58 PM
05 Jeep Grand Cherokee noise in right rear on acceleration. wuncbitten Introduce Yourself 4 12-16-2011 11:35 AM
brakes kick back on 93 jeep grand cherokee 36int Suspension - Brakes - Steering 2 05-22-2011 08:39 PM
Cant get hatch open on 93 jeep grand cherokee eric32 Body - Exterior 13 07-18-2009 05:30 PM
1998 Jeep Grand Cherokee Jeeper 4-Ever Transmission - Rearend 3 06-20-2006 08:59 PM
