I am rebuilding a late 60s early 70s Dune Buggy based a a VW. Best i can determine, the motor is a 69, no other numbers on the frame.
I want to title it so it can be driven on the road. That means horns, signals, etc. When I dug into the steering it looked just plain dangerous. Steering wheel held in place by 3 machine screws (no nut), base of column attached with a plastic wafer to a connector that was connected to the steering box with a cross drilled bolt. The end of the shaft does not appear to have any splines.
Anyone have any knowledge of these? What parts will I need to make this right?
