vw manx meyer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2013, 09:25 PM
vw manx meyer?
Anybody ever worked on or build a manx meyer i think they are really sharp. What all could be done to the engine to get more power i know alittle bit about a the vw engine but not a lot thanks
Old 06-25-2013, 09:32 PM
techinspector1's Avatar
Wiki Edits: 326
Bruce Meyers built fiberglass molds and marketed probably the prettiest little roadster since ever. The car was a VW pan with the body removed, shortened 14 1/2" and the fiberglass body bolted to the pan. It used the VW motor, trans and diff in their original locations. They were very popular when I was a kid.
https://www.google.com/search?hl=en&...mg.K2c1ixU8JHQ
Anything and everything is still available for the VW motor as far as I know.
Old 06-25-2013, 09:41 PM
Wiki Edits: 27
Corvair ?
I had 2 dune buggies with Corvair power, One use the VW front suspension pan, center tunnel hump removed and that sat on a Tube frame I built with Corvair rear suspension. the Car Corvair was geared too high. the second one used the VW trans axle with an adaptor plate. Pinto-Mustang II 2.3 were also popular. If you go to the Vw dune buggy forums you will find a lot of options , The summer volunteer Ranger at the St Anthony sand dunes near where we live runs an all aluminum Rover V8, apx 300 HP, a long ways from the old 40 hp VW s Try the.... Samba .....web site. For a VW you have lots of Options. A dual port AE can be done economically. I presently have an old rail buggy with a 40 Hp Bug engine , cheap and not very fast.
Old 06-25-2013, 11:07 PM
Your going to pay through the nose for a real Manx, there are lots and lots of knock offs. Some are pretty decent quality some are junk. The VW engine is probably the second most hot-rodded engine ever. Turbos are getting pretty popular now days if you want serious HP.
Check out TheSamba.com :: Index best vw website on the web
Old 06-26-2013, 06:04 AM
try the samba forum,
Old 06-26-2013, 09:42 AM
Them manx meyer are very high atound here more i thought about it a baja bug would be perfect because i have a camper in northeast ark in a little town of hardy its in the mountains and have tons of dirt and gravel roads with creeks going though them so roads are pretty rough and either manx meyer or a baja would be a blast
Scott Meyer my455TA Introduce Yourself 2 04-28-2009 06:02 PM
Jim Meyer IFS lt1tyrell Suspension - Brakes - Steering 4 04-23-2009 02:46 PM
1960 Meyers Manx VW Jack Sparks Electrical 4 03-10-2007 10:13 PM
gary meyer gary meyer Introduce Yourself 2 12-24-2006 06:49 AM
gary meyer gary meyer Engine 1 12-24-2006 12:20 AM
