VWs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2009, 06:48 PM
deadbodyman's Avatar
Wiki Edits: 11
VWs
are there any VW guys out there?I recenty bought a bug to play around with,after doing a couple donuts around the shop it started a terrible noise almost like the flywheel is wobbleing around in there,i disconnected the coil and itstill makes the noise with only the starter turning,any ideas?
Old 02-12-2009, 07:27 PM
Vw
It sounds like a broken flywheel to me, there is a good website with lots of VW info thesamba.com/vw someone on there will be able to help you.
Old 02-12-2009, 08:10 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Your user name got my attention
Deadbodyman + VW = Ted Bundy
(sorry---dry sense of humor )
Old 02-12-2009, 08:44 PM
Wiki Edits: 11
did he drive a bug? no wonder he chopped them up
Old 02-12-2009, 09:15 PM
woodz428's Avatar
Troll Hunter
I think the flywheel is the best place to start. They are held on by a large( 36mm,I believe) gland nut and have to be removed to set end play of the crank, it may have also been refaced during a clutch job and R&Rd. If not torque correctly they have been known to come loose. It will require engine removal to correct, if that's the case. An easy way to check without pulling the engine is to check crank end play at the pulley end. If it is excessive, that's a good indication that it needs adjusted or the flywheel is coming loose. There are 4 dowel pins that locate the flywheel, so it will still rotate with the starter. They will however cause damage to the crank and/or flywheel if not caught in time.
Can VolksWagens be Hot Rodded? MrPhotographer06 Hotrodding Basics 164 08-10-2007 10:53 PM
Trying to Understand CC's sharp21 Engine 30 01-21-2007 08:53 PM
Hey anyone know VW's need some help Rat_Rod_Ho Off-Topic 3 07-27-2006 11:40 PM
Anybody work on VW's??? VWFan Engine 4 07-19-2005 10:59 AM
