w&g remover on filler - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 06:29 PM
Nastynotch347's Avatar
Accidentally I got some on the filler, I have read that this is a no-no. Should I remove the filler and re apply or will allowing it to sit overnight be sufficient?
Old 05-01-2011, 06:51 PM
Just let it flash out good will be fine. Of course this depends on how much you got on it. If we are talking a filler on a hood and you spilled the gallon can on it with the whole gallon running across the plastic filler onto the floor I would say remove it and redo the filler. But if you were simply wiping with a wet rag and you wiped across the filler, don't sweat it. Let it flash out will be fine. A light sanding with the same paper you had previously sanded the filler with "opens" it up to flash better.
Old 05-01-2011, 06:56 PM
The wet rag was what happened, I will let flash for a couple more hours and lightly sand it so it can sit all night. Thanks!
Old 05-01-2011, 08:52 PM
I routinely spray W&G on the filler and wipe it off.. It's probably frowned upon.. But it usually sits for a few hours before I do anything to it, so.....
wax and grease remover confused Body - Exterior 2 12-27-2006 07:57 PM
wrist pin remover nix Garage - Tools 2 01-26-2006 02:02 AM
aircraft remover 6speedwagon Body - Exterior 4 03-17-2004 07:44 AM
paint remover Busted Knuckles Body - Exterior 0 03-11-2004 06:00 AM
Rust Remover Kevin45 Body - Exterior 2 12-07-2003 05:09 PM
