I'd reccomend switching to a more common master cylinder... Wagner M/C's are getting very hard to find ( as is most Wagner brake parts ) and most just rebuild the 1 they have
Replace that sucker with a 67-69 Corvette master cylinder. Get a new one, brakes are someting I never use rebuilt components on. The Vette master cylinder can be had in all disc, or disc/drum configuration.
Vince |
don't throw out the Wagner tho.. being there not made new, if it's good enough for a rebuild it's probably worth somthing to someone.. lots of AMC's used the Wagner brake parts.. not sure what that cylinder crosses to but it's probably somthing AMC
Matt, I'm going to look for a rebuild kit for the Wagner. Don't know whether I'll rebuild it or switch to the one Vince suggested. Do you know where I might get a rebuild kit for the Wagner?
most likely any good auto parts store could get the rebuild kit for it.. but they won't be able to go by the M/C numbers. so you will need to tie the M/C to a vehicle most likely, which as said before, is probably some kind of 1960's AMC.. Rebel, Ambassador and Americans all were optioned with Wagners as better brakes, and it would be a drum/drum master cylinder if it is an AMC unit, I'm 90% positive all AMC disc/ drum varaitions used Bendix brakes.. it would be easier and just about as cheap to buy the corvette master which is what 90% of manual under floor dual M/C setups run
The Wagner MC wasn't an "option" for better brakes. It was just used on certain models. Only the 65 and 66 Americans equipped with the 232 six used a Wagner setup (smaller sixes and V-8s used Bendix), all 58-69 six cylinder Series 10 cars (58-60 Rambler Six, 61-66 Classic, 67-69 Rebel) used Wagner brakes. All other AMC models used Bendix brakes.
AMC used outside suppliers for some things (like brakes -- but not that many parts) so kept standing orders from at least two different ones through most of the 60s. That way if one had a problem they already had a purchasing agreement with another -- eggs in two baskets instead of one. They just had to buy a certain volume from the secondary supplier to keep business, so the "alternate" part was usually used on a specific model. AMC still made the majority of their own parts, they just bought a few systems from others -- electric and ignition systems, transmissions, carbs, steering boxes and columns, and brakes were the only major parts they purchased. AMC started phasing this practice out by 1970. Apparently someone decided that the suppliers were big and robust enough that two weren't needed or the secondary supplier went out of business (in the case of Wagner brakes, at least in the US). I was going to add that production had dwindled, but AMC was still building a good many cars in the early 70s, especially the Hornet and Gremlin. Production of the big cars had slowed, but was still healthy for a few more years, until the mid to late 70s. |
Frank, not that it really matters in this discussion but aren't you missing my little 59 American?
GMR if you really want to find that one check out my thread in the "hotrodding basics" forum on finding parts in the specification books at the parts store. You may be surprised to find at what you find. I just bought a new master for my Rambler on ebay for $35. Brian |
Yes, I missed the early Americans entirely! Looks like they used the Wagner MC 58-60, Bendix after that except for the 65-66 oddball.
| Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? | mrwumper | Suspension - Brakes - Steering | 3 | 04-16-2009 09:38 AM |
| Dual Master Cyl on Willys Pickup | BT74 | Suspension - Brakes - Steering | 4 | 03-03-2008 12:49 PM |
| Stock Monza Master Cyl work with aftermarket disk brakes? | Quarter Flash | Suspension - Brakes - Steering | 1 | 11-19-2006 05:31 PM |
| brake master cyl question! | 67 Deuce 4 Me | Suspension - Brakes - Steering | 3 | 08-08-2006 12:47 AM |
| Relocating master cyl on a 34 | 302 Z28 | Suspension - Brakes - Steering | 8 | 11-16-2003 10:42 AM |
