Waking my beast (1967 Firebird 400) - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2006, 08:44 PM
In a nutshell, I bought a 67 Firebird 400 with a tri power set up that has sat for about 15 years. I am to the point of it firing up for a few seconds and then sounds like it runs out of fuel. I have fuel leaking out of the carbs at the bases. What would cause it to not keep running like that?
Old 10-15-2006, 08:07 AM
raidmagic's Avatar
Last journal entry: Engine going back in the Hudson.
If your carbs are leaking fuel they may very well be sucking air and that could keep it from running. Did you rebuild them after they sat that long?
Old 10-15-2006, 11:04 AM
machinist & fabricator
i have ran many carbs that leak....
in most cases it will just run like crap due to the leaks...
check your fuel lines, filter and tank
Crankshaft for 1967 400cid Firebird Nonsuch Engine 4 10-07-2004 02:19 AM
which 5 speeds will bolt up to a 71' firebird 400? Chirodan Transmission - Rearend 6 01-27-2004 06:26 PM
326 firebird engine swap with a 400 engine...is it possible?? greg67 Engine 7 11-08-2003 04:34 AM
Will Intake 454 fit on 400 Firebird Auto-Part Engine 6 11-05-2003 10:49 PM
Rear end for 67 Firebird 400 pringles Transmission - Rearend 5 10-09-2001 09:07 PM
