Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Walking foot needle feed questions
  #35 (permalink)
Old 12-09-2011, 07:10 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Here's how your machine should be threaded:
Pay particular attention to the two pictures on the far right. The bottom discs are called the thread controller discs, and the spring is called the thread controller spring. The thread goes over the top of and in between the two upper tension discs, under and in between the two lower thread controller discs, on the outside of the thread controller spring, and then gets pulled back behind the small curved hook on the inside thread controller disc. The thread can jump out of that spot and screw up your stitches.
ID:	60617   Click image for larger version
ID:	60618   Click image for larger version
ID:	60620   Click image for larger version
ID:	60623   Click image for larger version
