wallet breaking 454 W/ TBI - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2010, 11:35 PM
i have a 1993 34 ft. motorhome with a 454 had timing problem 13 degrees off advanced it ran great for a few trips. now having intake back fire again were it starts poping and losing power it has T.B.I injection on it was thinking of up grading to holley or edelbrock 3 in1 injection system only getting 4.5 mpg HELP!!!
Old 08-25-2010, 03:35 PM
Dirty Biker's Avatar
Bold As Love
Hi! How are you setting the ignition timing? Was it popping like that before you changed the timing? I have a motorhome with a 454 too, but has carb. Mine will still run ok even if the timing is pretty far off, but it will pop thru the carb sometimes if the timing is too retarded. I personally like to retard the timing a little when I am going down the road on a trip, and then advance it a bit when I am in town. Seems to run more relaxed on the highway with less advance.
Bold As Love
I get 8-9mpg btw
Old 08-25-2010, 08:24 PM
thanks for the feed back. timing was 13 degrees retarded, in the end did timing by driving and adjusting to best setting then never rechecked timing.it was popping and only able to run at half throttle did timing and thought it was fixed my bad. Injectors seem to be spraying way to much fuel to were it was running off carb flaps. Would msd ingnition help? 4.5 mpg is killing me
Old 08-25-2010, 08:26 PM
bigdog7373's Avatar
Of course it's fast
if it's running rich then it will be using more fuel. You need to fix that before you do anything else.
Old 08-25-2010, 08:39 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Also 13 degrees retarded is approximately 40 degrees from where a Stock BBC likes to run. You need to be in the area of 30 degrees ADVANCED. If the computer is retarding the timing this much and there is a rich condition I would look into your knock sensor. If the computer is recieving a knock signal then it will retard timing and add fuel until the knock stops. If it is an early system then it can be confused by other vibrations in the engine (rod knock, lifter noise, a loose belt tensioner bracket....just about anything.)
If there is no knock signal, then you need to look into the other sensors that tell the engine how much fuel and timing is required, TPS, MAP (and/or MAF), 0xygen sensors, ECT, and so on...if the system never goes into closed loop operation it will run very rich.
Swap TBI for Carburator - 1989 454 unstable Engine 11 07-26-2015 05:11 PM
454 tbi or dual tbi on dual 4bbl carb intake 90GMCVortec Engine 3 10-28-2008 03:48 AM
454 intake, vortec to tbi HOUCKXLR8 Engine 0 09-12-2007 08:02 PM
350 TBI to 454 TBI Swap NAIRB Engine 1 10-16-2004 04:51 PM
454 TBI Swap Junorr Engine 0 09-06-2004 04:58 PM
