-   -   Wanated: paint formula for Dodge Charger F6 Light green metallic (http://www.hotrodders.com/forum/wanated-paint-formula-dodge-charger-f6-light-green-metallic-148714.html)
RoadHouse Tim 11-25-2008 08:47 AM
Wanted: paint formula for Dodge Charger F6 Light green metallic
I'm working on a customers Dodge charger and need some basecoat so i can blow some areas in. i really need a PPG mixing formula but i can get other manufactures if i have too. the colour is F6 Light green and it's from a 68 car
thanks
BradD 11-25-2008 12:32 PM
Paint code
PPG Ditzler 43646, DuPont Lucite 4881L, DuPont Centari 4881A. I don't know the actual formulas(how many grams of each color to get the finish color).You should be able to cross reference these with a DBU or DBC code.
RoadHouse Tim 11-25-2008 01:50 PM
Thanks Brad, hopefully my paint supplier can make some use of the PPG code, if not i know someone that's got a Dupont scheme too
mitchell48111 07-17-2009 12:06 PM
f6 paint formula for a gallon of dupont croma base
830 J green 1131.3 grams
843 J bright yellow 1414.1 grams
801 J white (HS) 1549.9 grams
807 J black (LS) 1629.1 grams
175k binder 3796.1 grams
and you mix the reducer 4:1
