Wanated: paint formula for Dodge Charger F6 Light green metallic - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2008, 07:47 AM
RoadHouse Tim's Avatar
Wanted: paint formula for Dodge Charger F6 Light green metallic
I'm working on a customers Dodge charger and need some basecoat so i can blow some areas in. i really need a PPG mixing formula but i can get other manufactures if i have too. the colour is F6 Light green and it's from a 68 car
thanks
Old 11-25-2008, 11:32 AM
Paint code
PPG Ditzler 43646, DuPont Lucite 4881L, DuPont Centari 4881A. I don't know the actual formulas(how many grams of each color to get the finish color).You should be able to cross reference these with a DBU or DBC code.
Old 11-25-2008, 12:50 PM
Thanks Brad, hopefully my paint supplier can make some use of the PPG code, if not i know someone that's got a Dupont scheme too
Old 07-17-2009, 11:06 AM
f6 paint formula for a gallon of dupont croma base
830 J green 1131.3 grams
843 J bright yellow 1414.1 grams
801 J white (HS) 1549.9 grams
807 J black (LS) 1629.1 grams
175k binder 3796.1 grams
and you mix the reducer 4:1
Painting a Metallic in pieces Polish Painter Body - Exterior 18 09-11-2010 06:16 AM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 10:02 PM
