Want 300 to 320 HP from SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2010, 09:59 PM
Babyburr's Avatar
Building a T-Bucket and will be running a 350 chevy. Is 300 to 320 HP possible on a budget of $1200 to $1500???
Thanks for any and all suggestions
Old 08-21-2010, 10:20 PM
DoubleVision's Avatar
Slap a set of RHS Vortec heads on it, Edelbrock performer vortec intake,
A cam with around .224 duration @ .050, double roller timing chain.
That`ll easily meet your goals and then some.
Old 08-22-2010, 02:13 AM
spinn's Avatar
The 350 Performer package is something to be proud of. Add a performer cam .420/.442" lift, and the performer intake on a 8.5:1 350, things happen. Burnouts , pulling acceleration increase, even with 2.76 gears from idle to 4500 rpm. 50* of overlap offer a noticeable idle stampeed. One of the best road cams ever ground. Not for racing , but it makes a quick, reliable, daily driver.
cam $48
intake $40
springs $35
gaskets $25
might go 290-300hp, and makes all the cool noises. burnouts, secondary open forced downshifts, idle purr, and a economic cruise.
Old 08-22-2010, 03:34 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Get on craigslist and buy a set of vortec heads.
Buy this cam http://www.compcams.com/Company/CC/c...x?csid=84&sb=2
use flat top pistons, 86 octane gas, and make an easy 310 hp with a cheap factory shortblock.
/thread
Old 08-22-2010, 08:29 AM
buy a used 1996 to 1998 350 vortec roller cam engine (in good shape, 275hp stock), install a rpm intake, 750 cfm 3310 holley, and a set of headers. should make 300hp. If you still have some cash after that, then change to a mild cam (212 to 218 degrees at 0.050").
Old 08-24-2010, 07:47 PM
heck yeah, im with spinn, i have a 350 std bore with flattops "345np's", with x-rods or "pink" rods as they say, a performer cam 420"/442" lift, a set of double humpers "461's", a perfomer intake, and the perfomer 600 carb, 15/8's dynomax headers through 21/2 pipes, lets just say with 2:14 gears, it will leave 75ft of single wheel rubber, and thats not power brakeing ether!!!
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Need advice on building a 300-320 hp SBC 350ci 075turbo Engine 26 01-10-2010 09:02 PM
high hp low tq sbc blight Engine 61 07-23-2009 07:09 AM
HELP!!! I Want 2 No How Many Hp Does My 350 Sbc Have...?????????? jkingof9561 Engine 2 04-29-2008 01:11 PM
sbc head HP jrmz28 Engine 0 07-14-2005 09:58 PM
