Want a 4-speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2012, 02:33 PM
bsa_bob2's Avatar
Want a 4-speed?
I am building a 55 chevy and have a chance at a saginaw. This trans looks longer than i remember back in the 60s. Its also -looks good. Theres no levers on it, and it has three places for these levers, Are these hard to get? And i remember there was the muncie, the T-10 rock crusher, This saginaw is selling for $225.00 this sounds abit to cheap. What can you help me with? and what trans should i hold out for.I'm not going to power shift or anything. just want to get a little rubber once in awhile . help if possible. I remember how much fun the 4-speeds were to drive . I am putting a 350 in the kar bob s
Old 05-16-2012, 03:25 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I would hold out for Super T-10 if it was mine anyway.JMO
the sag would be ok for awhile but just wouldn't get it for me if i did want to get in it pretty good every now and then. IMHO
Cole
Old 05-16-2012, 08:49 PM
MI2600's Avatar
Member# 3287
Be careful. A lot of those Saginaws have a 3.11:1 first gear.
Old 05-17-2012, 08:28 AM
Its not so much the type of 4 speed as it is the RATIO.
If you're going to run 3.42, 3.55 or 3.73 you really need a trans with something like 2.50, 2.64 etc for a 1st gear. No 2.20 ratio stuff.
Sag should be fin for what you're doing, although Id have someone open the sidecover and take a look around. Magnus Racing Products in CT handles a lot of new and used Saginaw parts
Old 05-18-2012, 01:09 PM
bsa_bob2's Avatar
thank you for the magnus info. I jUST visited their site they show a saginaw------with no third lever on the side for reverse.Somebody said to beware of some of these saginaw 4-speeds! ring a bell with you.or anybody??? bob s
Old 05-18-2012, 02:47 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
GM also used an New Process A883 transmission in the 80's. I heard that this was originally used on Dodges, then ported over to GM. It is a 4 speed, but 4th is over-drive. They are also cheap!
http://www.classicjunkyard.com/new_process_a833.htm
Old 05-18-2012, 04:58 PM
bsa_bob2's Avatar
that is some great info....i would imagine being harder to find as compare to the muncie.Did the middle 60s vette have muncie 4-speed in them?My old 65 vette was a great shifting trans and she was better at shifting it than i was.muncie is most likely what i'l do, with the stock stick rear end thats already there. bob s just finfing a good one and a decent price i guess.
1951 Chevy business coupe, replaced the 3 speed with a 4 speed transmission. EricKessel Transmission - Rearend 1 08-08-2011 08:35 PM
4 speed auto-5to6 speed manuel R4MM Transmission - Rearend 6 05-26-2007 09:54 AM
replace a 5 speed with a 6 speed? dtprula Transmission - Rearend 3 12-17-2004 04:32 PM
Next upgrade for the money pit. A 4-speed. Which 4 Speed is the best choice? killerformula Transmission - Rearend 3 05-26-2004 03:54 AM
difference in 2 speed to 3 speed auto? HemmiGremmie Hotrodders' Lounge 2 12-17-2002 05:31 AM
