Want to Add Sway Bar to Rear Axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2005, 12:26 PM
I have a 37 Plymouth P-4 Sedan with a stock frame and a 1970 Camero eight bolt rear end bolted to stock '37 Plymouth leaf springs. I would like to add a sway bar and have tried to find something that would work. So far, I have not had any luck. Is there someone who has a '37-38 Plymouth w/ a GM rear axle that has set up a sway ar on it? I'd really like to know what you used and how you connected it.
Old 05-31-2005, 04:51 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
You might check into circle track style sway bars.
Old 05-31-2005, 05:27 PM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Might try www.chassisengineeringinc.com
they have some universal applications that might work
Old 11-22-2005, 02:00 PM
I used a sway bar from a 1989 Camaro on my 38 Chevy sedan. Pretty similar dimensions to your Plymouht. I had to pull the ends of the sway bar in about an inch or two, but it worked out fine. I fabbed some end mounts out of 2x4 squar tubing and made some rear end mounts out of exhaust muffler clamps. I got the urethane bushing mounts for the ends at Advance Auto Parts. Then mad the frame mounts to fit the bushing mounts. It was not a bad project at all and looked pretty good.
Old 11-22-2005, 04:24 PM
I've drawn up some ideas for the link mounts. A mid-80's Camero sway bar sems to be the bar of choice. Now it is off the the shop to fab up the parts and get it done.
Thanks for the help.
Old 11-23-2005, 04:24 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Stiffening the forward half of the leaf springs makes the springs themselves act like an anti-roll bar and a traction bar.
Looking for pix of rear axle setup... S10xGN Transmission - Rearend 1 03-27-2005 12:17 PM
Rear sway bar -custom? Rich_Long Suspension - Brakes - Steering 1 08-17-2004 01:45 PM
Is a panhard bar appropriate for an elliptically suspended solid rear axel? jpd37 Transmission - Rearend 12 12-17-2003 12:14 PM
rear sway bar DeathByGreaser Transmission - Rearend 2 02-07-2003 03:25 PM
Sway Bar Installation...do it. F-1Rodder Suspension - Brakes - Steering 3 09-19-2002 04:01 PM
