I am looking for parts info in direction of which block,rods,pistons and any extra machining I might need to do.I already have a 69 428cj crank,from my last project.Can I over bore a 352-390 bock or do I have to use a 428 block?Heads and intake are already taken care of with edelbrock aluminums and an offenhauser high rise dual 4 barrel intake.The motor will probably never see the track,only being insured for 3 months a year.It's a toy truck.Thanks
A 410 is a 390 block with a 428 crank. (4.050 x 3.980). I suspect you could bore a 332 or 352 block 0.050" to the 390 bore and be ok. The biggest problem might be finding affordable pistons.
You also may be able to bore a 390 block 0.080" and make a 428. It would depend on the thickness of the cylinder walls and how much core shift there is in the block. You need a minimum of 0.135" cylinder wall thickness everywhere in the bore after boring and honing to your final dimension to prevent overheating problems (according to Smokey Yunick, who has built a few more motors than either one of us). Sonic check the walls before you do anything else. You'll need to start with 0.175" walls on a virgin 390 block to end up at 0.135" walls with an 0.080" overbore, or 0.160" walls on a 390 block that has already been bored 0.030" or 0.145" walls on a 390 block that has already been bored 0.060".
While it would be neat to have a 410 FE tech insp. is right pistons will be your major expense as the 410 uses the same rod length as the 390 and 428 (6.486-6.490) in all the listings I can find. This would put the wrist pin height at a different level than the 390 because of the extra stroke. But overall if your not going after a super performance build then off the shelf stock parts may be much cheaper if you can locate them.
Here's another link that gives spec's for the FE's
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
