Want to build an SBC on alcohol - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-21-2012, 04:12 PM
vinniekq2's Avatar
when you figure out what you need,why not start a new thread and say Im using X fuel and need an N.A. or boosted engine? looking for x power? need X rpm,etc and go from there.Explain rpm requirements and if the engine is strictly race,,,just picking a horse power number means nothing to people trying to help.explain (briefly) h.p. torque,rpm requirements etc and get everyone to chip in experience.
  #17 (permalink)
Old 10-21-2012, 10:37 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I have a friend that has an Ostrich 360 Sprint car motor for sale for 15K. Can probably be had for a touch less. Dynoed at 650 I believe, ready to run. You can search racingjunk.com or hoseheads.com and find plenty of what you are looking for. Keep in mind that all the high reving motors have to use good quality parts to keep them together and even then, they get freshened up after about 20 shows. Word of caution, unless you have lots of money for parts, stay away from the SBC 410 sprint motors. Those things will scream and capable of 900+hp but they are very costly to maintain and need freshened after about 10 shows. Most sprint car motors are built with restrictions for their sanctioning body so with a little work, you can get even more power out of them.
We run a SBC 383 Hilborn Injected on alcohol in our wingless sprint. We run the W.A.R. series here in Missouri so restrictions in that class do not apply. It's more like "run what you brung". Alcohol wants high compression, the more the better. Keep in mind that an alcohol motor is a maintenance nighmare but if you have time to keep it in good working condition, it's worth it because of the x-tra HP. You need to drain the fuel lines, remove the injectors and blow dry all the alcohol out of the system. Alcohol is very corrosive on aluminum and magnesium parts.
I know probably none of this answered your questions but it's an insight to start with.
If you do not want to register, fill this field only and the name will be used as user name for your post.
sbc build Old bones Engine 11 03-20-2011 05:33 AM
sbc build. v8_mazda_b2200 Hotrodding Basics 3 02-11-2011 07:26 PM
sbc build mikey1476 Engine 5 02-19-2009 01:05 PM
Building a SBC Alcohol Motor S10 Racer Engine 1 08-03-2008 10:52 PM
Alcohol Hondakillr11 Hotrodders' Lounge 48 07-19-2003 06:31 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
