want to change frame HELP................. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2011, 02:37 PM
Howdy Gents and Ladies,ive just purchased a 1931 cadillac sedan. want to put in new running gear. this is my first RODEO. getting to old for any more.would like to do this one right but inexpensive as possible. WOULD APPREICIATE ANY AND ALL ADVICE AND HELP...THANKS ,RON
Old 11-05-2011, 02:43 PM
Unless the frame is too rusted to be repaired, the frame the car came with is the best one for it. Most folks here will tell you that it's far easier to update that frame with modern engine, transmission and suspension than it would be to mount the body on a different frame.
This is especially true since, as you say, this is your first rodeo.
The '31 Caddy is an unusual choice for a first-timer. I am very excited to see what you'll do with this car. Please keep us informed on your progress!
Old 11-05-2011, 02:54 PM
Yes, that is an extremely challenging project even for an experienced builder.
There are no kits of any kind for anything on the car. Original parts are VERY hard to come by, the body has a wood structure (likely rotted away), there is nothing easy about it. Building the car will take much, much more work than building a more common 31 Ford model A, I mean a LOT more work.
Without knowing anything about the car, chances are it is also much more valuable than the Model A, maybe it would be better for you to sell it and get something that wouldn't be so challenging?
Tell us more about this car, do you have any photos?
Old 11-05-2011, 09:59 PM
life is a temporary assignment
BUT !!!! The journey is always much more fun then the destiny....
Old 11-06-2011, 10:13 AM
Wiki Edits: 27
caddy frame
I looked an old caddy frame that was under a hay wagon. The frame was massive compared to fords and chevies and looked very strong, AS stated unless it is rusted-rotted out It should work ok. The next step is to determine what you want to build. IFS swap or 50's chevy pickup axle with a disc brake kit. later rear end , power steering etc.
Old 11-06-2011, 10:18 AM
When we did my brothers Buick Roadster the Buick frame was counted out right quick, it was about 10 inches tall! We used a 28 Chevy frame instead it was more the 32 Ford size.
Old 11-06-2011, 11:26 AM
There is NO frame made that will fit the 31 Caddy better than the frame Cadillac installed over 80 years ago.
A 31 Caddy is a very rare and mostly desirable vehicle. It is very, very rare to see one Hot Rodded. Because this is your first RODEO ... I strongly suggest you sit down and sturdy the car a lot. Is it beyond you first timer talent? I have been building cars for over 40 years ... and I would have to think long and hard before I messed up such a rare and desirable vehicle.
DEUCE ... Moderator
Old 11-06-2011, 11:36 AM
DEUCE ... Moderator
That is exactly how I see it. I am a car lover, a preservationist as much as a hot rodder and I think the respect of the car in either way is in my mind at all times. This Cad, be it ANY condition may be better in the hands of people who can use the parts for another car at the least, or restore to original if possible than to hot rod it.
There are SOOOOOOO many super cool hotrod worthy cars out there that can be had for a song these days I see no reason to cut up such a classic car.
change of plans in frame design matt167 General Rodding Tech 8 03-09-2011 06:58 PM
41 pontiac frame change Madmax20050 Suspension - Brakes - Steering 2 07-07-2010 12:48 PM
53 chevy pickup frame change robert forshee General Rodding Tech 8 01-11-2006 09:30 AM
body change to later frame streetrod936 Suspension - Brakes - Steering 11 12-15-2005 08:44 AM
Won't change,wont' chang,won't change Samrupert Transmission - Rearend 6 01-11-2003 02:32 PM
