Want to install a Hazard switch in a 1954 Ford Customline - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2008, 09:33 PM
I am rewiring my 1954 Ford Customline with an EZWire Harness Kit. My Ford did not originally have a Hazard Switch but the Kit comes prewired for one. How can I use this kit to install a Hazard Switch on my Ford. Do I run it off of the turn signal wires? What kind of switch do I use? The kit comes with a Hazard Flasher, a Hazard Power Wire, and the Hazard Feed Wire. I would greatly appreciate the help. Thanks.
naystcb
Old 11-30-2008, 09:44 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
I had a 1966 Ford Galaxie, which had it's 4-way flasher switch mounted inside the glovebox.
The cool thing was that you could flip on that switch, step on the brake pedal, and listen to he radio without having the keys in the ignition!
I have no idea why that worked!... LOL
Old 12-02-2008, 06:38 PM
38mag's Avatar
I used a 4pole, double throw, 2 position switch from McMaster Carr.
need wiring diagram 1954 ford car btull Electrical 1 04-28-2007 08:35 PM
Custom Wiring A Hazard Switch horvath Electrical 5 05-12-2003 09:13 AM
9" ford ring & pinion install. kid Transmission - Rearend 4 05-07-2003 09:25 PM
Ford C4 neutral safety switch 37fordslantback Electrical 1 02-27-2003 03:05 AM
5.0 ford install gerry Engine 1 06-18-2002 01:48 PM
