want to know the difference - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2012, 04:24 PM
whats the difference in the 406 sbc with 5.7 rods an one 6 in rods
Old 02-11-2012, 04:33 PM
WDCreech's Avatar
Grumpy Old Goat Herder
.3" difference in the pin location in the piston, ala different pistons and a different rod/stroke ratio.
Old 02-12-2012, 11:02 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Scroll down on this page to Tech Tips - 2005 and read what Iskenderian has to say about it.
http://www.iskycams.com/techtips.php
Then, there's the issue of the 6" rod putting the wrist pin up into the same area as the oil ring. I don't care for more complexity to support the rings, so I would use a 5.700" rod in a 383/388 build. Keep it simple.
As Ron Iskenderian says in the tutorial, change rod length ONLY when you have exhausted every other avenue in your quest for power.
What is the Difference seven1nova Engine 6 03-21-2007 11:25 AM
What's The difference between an M20 and a M21 JimKramer Transmission - Rearend 5 02-16-2006 07:43 AM
mpg difference between i-6 and v8 nitsud08 Engine 27 04-17-2005 08:57 PM
BBC/ SBC cam difference joefromcocomo Engine 1 02-21-2004 12:27 PM
MIG/TIG what's the difference????? spl_dodge Hotrodders' Lounge 4 05-23-2003 05:24 AM
