Want to know how much power your engine is making? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2008, 02:49 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Alright Gents
I just ordered the Engine Analyzer Pro v3.5 after using their trial software for about a month. The software should be here in a few days and I am Jonesin' to input some engine setups.
I have the software down pretty good and some of you may have seen some results posted as images or files in some recent threads. I have the trial until the 19th and the software should be here by the 18th.
If you want me to input your engine setup to see what kind of power it will make please let me know, and the more specific you can get the better, I can select from just about any of the popular stock castings as well as the full catalog of Brodix, AFR, Edelbrock, Indy, and a few other Manufacturers of heads, as well as all the stock High Perf camshafts, crane, comp, and alot of mopar and bowtie parts. I can also input specs on any short block, heads, intake, carb, exhaust system, with a full range of climate and altitude settings, as well as fuel octane.
There are also screens to watch the engine in action, to check for piston to valve clearance and calculating cylinder pressures. These results will be more accurate the more specific you are. And we should be able to get within 5-10% of actual. And if we can't I want my 450 bucks back.
Let me know what you have and I will tell you what it will do.
Old 01-15-2008, 03:17 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Thats a generous offer, kind of like asking IRS for an audit, brace yourself for the hit.
I for one would enjoy inputting my motor, I'll send you some data when I get home from work this evening, you prefer a PM? Can you input boost numbers as well?
Thanks, Larry
Old 01-15-2008, 03:26 PM
Double_v23's Avatar
Yeah there are specs for nitrous, turbos, centrifugal, and roots blowers. Here are the screens for those specs
Name:	example centrifugal blower.png
ID:	27074   Click image for larger version
Name:	example roots blower.png
ID:	27075   Click image for larger version
Name:	example Turbo.png
Old 01-15-2008, 03:27 PM
Double_v23's Avatar
Oh and yeah I imagine I will be running numbers for quite some time.
Here are all the possible inputs for the specs of the motor itself, if you have crane, or comp part numbers for your cams, or casting numbers for your heads then you can tell me and those screens will fill in themselves.
I couldn't make a graphic of the screen for conditions but if you want you can tell me the weather (air temp, barometer), altitude, octane, nitrous (how many stages and what they are rated at, or progressive), and if you have a specific spark curve or if you want to use the one giving best power.
Name:	Example short block.png
ID:	27077   Click image for larger version
Name:	example heads.png
ID:	27078   Click image for larger version
ID:	27079   Click image for larger version
Name:	example exhaust.png
Old 01-15-2008, 04:54 PM
Double_v23's Avatar
Here are the results for Randywr's 383
pkTq 446@4000 rpm
pkhp 353@4500 rpm
and again with 1.6 rockers
448@4000
356@4500
The graph in the next post shows the different power curves
Name:	graph for randywr.png
ID:	27085   Click image for larger version
Name:	results for randywr_Page_1.png
ID:	27086   Click image for larger version
Name:	results for randywr_Page_2.png
ID:	27087   Click image for larger version
Name:	results for randywr_Page_3.png
ID:	27088   Click image for larger version
Name:	results for randywr_Page_4.png
Old 01-15-2008, 04:55 PM
Double_v23's Avatar
Here are the different torque and HP curves
Name:	graph with 1.6 rockers.png
Old 01-15-2008, 05:12 PM
can you run my engine combo please. Its a 327 bored .30 so its a 331 stock bottom end, trw forged pistons 10.1 compression, heads are worlds sr torquers 202 160 170 intake runners, 1.5 roller rockers, comp cam 274 extreme energy 230 236 @50 and 487 490 lift, edelbrock performer rpm intake, 600 holley, 1 3/4 headers into 2.5 inch flow master 40s, can you run it with open headers and then see what it is with mufflers, also just courious it i could get more hp with a airgap intake and a 650 holley, thank you John
Old 01-15-2008, 06:18 PM
Double_v23's Avatar
Bracketracer I will get to yours next but for right now here are the results for mpate
There wasn't alot to go on, and as always pay no attention to the labels they are usually left over from an example that I start from to save time. I guess I don't have the more recent Lunati's on file but I picked an older one that was similar and entered your specs from the 60100, I think you could go with a 60103 and see big gains. Especially if you are going to run at over 5000 rpm at all.
PkTq 403@3500
pkHp 329@5000
As you can see this combination would make for a very smooth power curve and would drive nicely, from the programs analysis your combination could use a more aggressive cam. Your Idle Vacuum will be 18 hg which means that your cam could increase duration without scrificing driveability, and you would see significant power gains.
The second graph shows the additional gains from a 60103 and your idle vacuum drops to 13 which is right in the range you want.
Name:	graph for mpate.png
ID:	27096   Click image for larger version
Name:	graph for mpate with 60103.png
Old 01-15-2008, 06:28 PM
Double_v23's Avatar
Ok I have to go and pick up some heads from the machine shop so I will do some more calc's later this evening.
Old 01-15-2008, 06:40 PM
hey if you dont mind you could do my set up also. Its a 383 bored .30 over with chevy cast iron vortec heads 170cc intake ports combustion chamber 64cc and 1.94'' Int./ 1.50'' Exh. with lunati 00016 hydralic flat tappet 218 duration intake and exhaust and 458" lift intake and exhaust. Edelbrock performer RPM intake and a 750 holly carb. this engine wont see over 5500 rpm. Could you tell me what cam would work better with this set up. i dont know on headers yet but with 2 1/4inch dual exhaust.
let me know if you need any more info.
thanks
Old 01-15-2008, 08:45 PM
I have one for ya!
383, 10.4:1 Speed Pro .030 pistons
Summit 200cc, 64 cc chamber Alum. heads:
2,3,4,5,600 valve lift
2.020 Intake 123 181 230 253 261
1.600 Exhaust 100 145 164 171 176
Victor Jr Port Matched
Holley 750
Hooker 1 5/8 long tubes, 2 1/2 flows dumped before the axle
Cam - Lift 549 Intake, 515 Exhaust
Duration at .050, 254 Intake, 262 Exhaust
Intake Opens 47, Closes 75
Exhaust Opens 86, Closes 42
Lc 108
Edit- Revving no higher than 7000
Old 01-15-2008, 09:14 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
how does this compare to the ez dyno?
Old 01-15-2008, 09:18 PM
nastynova's Avatar
Double_v23,
Your fingers will be tired before long...
350 30 over - balanced, Forged JE pistons 14:1, AFR 210's, Edelbrock Super Victor, CompCams Solid Roller 12-906-9, Holley 750 DP, MSD Probillit Dist.(locked out @ 36deg) MSD Digital 6 Plus Box , 1 7/8" Primary tube headers, forged crank, forged H-beam rods, diamond stripper windage tray,
Thanks...
Old 01-15-2008, 09:53 PM
I'll toss mine in if your bored
L69 305
.020" over
9.8:1 compression
ported heads (appear to be)
performer eps intake
1406 performer carb 600 cfm
1'' spacer
Full length headers 1.5" primiaries 3" collecters
True dauls with homemade low restriction mufflers
Emissions exempt so no emissions equipment
Output numbers in Flywheel Gross HP would be nice
I am seriously considering a fulie LSx since they have the little controller boxes out now
Thanks
Shane
Old 01-15-2008, 10:03 PM
Double_v23's Avatar
thanks
Ok back at it again,
With headers and 2.25 exhaust.
PkTQ 441@3500
PkHp 338@4500
Actually you done pretty good, if you look at the graph you have a nice flat torque curve and it is all in your useable RPM range, that you specified
I ran it again with a comp xe256H and there were gains of 4 ft/lbs and 1 hp then again with a comp 270h which requires some lower gears but can still be used with a stock torque converter and got less torque and a few more ponies it was all pretty close though and a lot less driveable.
I think you made some good choices, you probably could save some hassle by getting a smaller carb (650), so you wouldn't have to tune it as much you would lose a couple foot pounds and hp but it might be worth it...Just a thought!!!
I mislabeled the graph but that is for your motor. SBCfan
Name:	graph for bracketracer.png
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Low compression Engine. Can I make some power? Deezildennis Engine 6 02-02-2008 07:08 AM
turn my engine backup to get the power i had koop Engine 1 05-01-2007 12:04 PM
how much power will this engine make? CombatWombat Engine 13 01-13-2003 11:25 PM
What can i do to add power to my engine 94 CADFLTWD Engine 2 11-10-2002 11:14 PM
