Want to Lower 1984 silverado - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2012, 02:40 PM
malibuman402's Avatar
i have an 84 silverado. i want to lower it. the rearend sits under the rear leaf springs. is it safe to put it on top of the springs, and are there kits avialable to do this?
Old 10-31-2012, 02:54 PM
Yes there is they call them flip kits although i just buy perches center the axle set pinion angle weld it on cut the old perch off and put it back together
The Following User Says Thank You to monster76 For This Useful Post:
malibuman402 (10-31-2012)
Old 10-31-2012, 08:26 PM
Dennis W. Parks
For an '84 Chevy truck, I would strongly suggest Bell Tech or DJM, as they both make great components. Look over their websites or catalogs, determine how much drop you want, and then go for it. You should always get an alignment after lowering a vehicle. You should also learn how to drive a lowered vehicle... much of that is simply by doing. But, after awhile, you'll learn how to cross railroad tracks and enter driveways without scraping, but still have your truck to "sit right."
Dennis W. Parks
Author of automotive how-to books
Old 11-01-2012, 06:01 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders
I moved your post to this new thread. Please do not post your new questions into another member's old thread.
Better response to your problem when you post in new thread
Old 11-01-2012, 06:24 AM
Last journal entry: was hoping for better than this
your front end is basicly the same as chevy trcks all the way back to the mid 60's
2-3" drop springs are the norm..
I'd use drop spindles. and then a 1" or 2" drop spring..
the rear.. you can use a flip kit. to drop the rear 3-4" and then chackles if you want to go a little lower..
I'm guessing we are talking 2wd not a 4x4..
your truck 1973-87 front end is the same..(72 back the a arms are in different type bushings and you different rotors..spindles..
it shouldn't be all that hard to find drop spindles used.. as a lot of people have moved to air bags and now have these static drop parts sitting. for sale..
others use drop a arms.. that basicly lowers the spring pocket in the arm.. and leaves that pocket low and easy to catch on stuff..
springs and flip kit will be the cheapest..
take to a good alinement shop about the pros and cons.. of the springs..
and everything else..
I don't like big drops with springs as it most times requires a lot of shims at the upper a arm shaft... and then they don't hold alingment for long..
good luck..
your truck.. many vendors make parts to drop it as low as you'd ever want.. from normal lowering to laid frame..
spindles allow you to keep the wheel travel. springs and drop arms don't..
1984 350 C10 Silverado electric choke tcoop Engine 9 10-20-2012 08:33 PM
1984 Chevy Silverado Niknik75 Introduce Yourself 2 03-20-2011 07:21 AM
Lower compession = lower octane? Arrowhead Engine 8 11-18-2007 05:45 AM
How much lower will the frame lower once the real motor is installed ? Tonythefish Suspension - Brakes - Steering 3 02-05-2007 04:14 PM
1984 5.0 H.o.? Barz51 General Rodding Tech 2 08-19-2003 03:32 AM
