Want To Lower My 56 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2007, 11:38 AM
I Have Put A New Set Of 17" Tires And Wheels On My 56, But Now I Have Too Much Room Above My Front Tires. I Think It Would Look Much Better Lowered Approx. 2 Inches. Would Like To Know Cheapest Way Too Lower. I Have Heard Of Cutting Coil Springs To Lower, Is This A Good Idea, And If So How Much. Also The Back Will Need Lowering About The Same Amont, What's The Best And Cheapest Way To Lower It. I Looking To Put Power Disc Brakes On It Later On When More Money Becomes Available So This Plays A Big Part In How. Disc Brake Setup For Stock Spindles Are Much Cheaper If I Don't Have To Buy Drop Spindles.
Old 02-22-2007, 12:55 PM
For the front you can buy ball joint spacers, for the back use lowering blocks. If you cut the front springs keep in mind that cutting off 2" will lower the car more than 2" because the heat will remove some of the temper from the spring making it sag even more over time unless you cut it with a cutoff wheel and keep the heat controled with water. You would be better off to buy drop spindles set up for the disc brakes which you said you had planned for the future anyway.
Old 02-22-2007, 01:32 PM
Lower 56 Chevy
Thanks For The Suggestions I Will Check Into That.
Old 02-22-2007, 02:16 PM
lamothe1's Avatar
If you want a lot of info on lowering your '55 go to chevytalk.com. They have a forum on tri 5 chevys.
Engine build ideas Rug Engine 23 12-25-2006 02:39 PM
56 chevy original engine value DaSouthWon Engine 3 04-18-2006 06:38 AM
56 Chevy Doors bob barker Body - Exterior 1 02-24-2006 07:37 PM
56 Chevy Body Question bob barker Body - Exterior 4 02-02-2006 11:57 AM
'56 Chevy wagon in Northwest Indiana oldstreetrodder Introduce Yourself 1 08-12-2005 06:09 PM
