Would a more appropriate question be, "How can I increase the torque and/or horsepower?" Compression is just one factor of combinations of components that are put together for performance.
As I'm sure you realize and have seen from the coupla responses you've already gotten, you need, of course, to get into the engine to one degree or another. Could I suggest you investigate the HP/torque question and just let compression be one of the possible factors for change. Recommendations for increased HP might likely result in increased compression, but addressing the question as you have is kind of a back-door roundabout way to explore performance increases.
I am assuming, of course, that increased performance is the ultimate goal??? . . .not just compression for compression's sake.
good luck.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
