Want more power out of 427
Hey everybody I have a few questions in hoping you can help me with. A friend of mine currently has 427 bbc that ran 520hp on the dyno. Now after a few years he wants more power closer to 650hp. No nitrous. He is on a very strict budget. Now the motor has forged crank and forged domed pistons. Now I thought in my mind he could disassemble the motor have the pistons milled down to be flat tops giving it around 8.5:1. Put a weiand 177 blower ontop. Possible upgrade to a hydraulic roller.
Would this work? If not could I get input on what you guys would recommend? This is strictly a street motor in a 71 gmc half ton. Thanks a bunch |
He has the 781 oval port heads. They have been ported with 2.19/1.88 valves.
I can't see it being very expensive to do that's all. Because all he needs is to lower the compression change cam and stick the little weaind 177 on there? Or am I missing something? Is there a way to tell if the done is hollow or not?? |
He is just looking for a way to get around 650hp or so and we figured this would work fairly good.
Can a person get that high with just changing to better heads and upgrading to a hydraulic roller? It's currently a solid flat tappet right now. |
^^^^^X2
the reason most people are saying that going the blower route will be expensive is for 1 the blower is going to cost 2500+ to get it delivered. Then I would say that it would be a little dumb to run a blower on facotry heads (just my opinion) and I'm not sure those heads in the shape they are in can even support 650hp. So there is a set of aftermarket heads, 1800-2500. To do this he is looking at 5,000 easy, and that doesn't include the machine work to the pistons (i'd just buy new pistons). Since this is a 427 BBC which is basically the same block as the 454 BBC just with a 396 crank, I would say go after building a 496, he'll have about 2500 into the rotating assy and the machine work. Then go after the aftermarket heads, and probably another cam. It isn't too hard to make 600-650hp out of a 496 (with the tq to match). Then later on if he decides he wants even more then he could toss a blower on it and be in the 750hp range (suposing the block and other parts hold up). |
my87z is correct
what I said,heads = 60 plus hp.50 cubes will add 60 plus hp,torque would go up. or like I said 60hp for better heads and maybe 20 more with a roller cam,thats 600,,, blower or 496 will both need new pistons. do the math on the cost of parts and see what works best for the situation? a 496 can use bigger heads than a 427 so more power potential there |
Doesn't seem reasonable to expect 650 out of a little 177 and 427 c.i., that's JMO>...
Midnight Sun Street Rod Association |
I agree. I'm no engineer, but from what I've been able to put together over the years, good engineering practice dictates that the crown thickness will equal about 7% of the diameter for a naturally-aspirated piston. The crowns on dedicated blower pistons will be thicker than those on naturally-aspirated pistons, so you would want to be adding material, not cutting material away. I don't know what the percentage of crown thickness to diameter would be with a dedicated blower piston, but common sense tells me 8% to 9%.
2.33:1 drive ratio. Even on a SBC. on a 427BBC w ported big valve oval ports its no sweat. Low compression, 7.5:1 suitable street solid flat tappet or solid street roller cam. 248 to 255@.050" duration. big carb. 2.33:1 drive. A Comp XR286H-10 cam or a custom blower version of this cam ground on a 112-114LSA will get it done with the 177 on a 427BBC. Lunati street roller cam #502A3LUN would be another example Lunati flat tappet cam #402A4LUN will get it done very nicely on a budget. A hyd cam or a hyd roller cam will really limit this motor. lowering the compression is easy on this motor. Just replace the pistons with 427 forged flat tops. Or get a 454 crank and use Common low cost forged L2377 454 flat top pistons. Picking up 20cubes is a bonus. this motor will easily make 650 hp with a 177 blower but I would get a Weiand 8-71 and two 750 edelbrocks for it on this motor. (+ the solid or solid roller blower cam) ( bet this motor has a lame hyd cam in it now and that is a big part of the current HP limitation problem.) Cutting the dome of the present piston would be a big mistake. Last edited by F-BIRD'88; 10-06-2012 at 02:15 PM. |
I would swap out the camshaft for something like this one from Lunati Street Strip Hyd Cam - Chevrolet Big Block 285/295 - Lunati Power then buy you a 100-150 shot cheater nitrous system, good street motor then nos if you go to the strip.. 100-150 is pretty mild shot for bbc.. this setup may cost you less than $500-$600 you get the power you want and have fun for lot less than a 2 grand blower adder not blower wouldnt be cool, but i think you dont have the right SCR or the right setup for it, NOS just bolt on and go once you learn a few detail before you run it, not hard, just common sense
| 427 HP q'S | 56chev100 | Engine | 13 | 10-24-2009 11:32 AM |
| 427 T | DoubleVision | Hotrodders' Lounge | 1 | 05-30-2009 01:35 AM |
| Z11 427 W Blk or L88 427 which would pull ahead | Quarter Flash | Engine | 4 | 03-26-2008 06:35 PM |
| What is the differrence between a 427 chevy bb and a 427 chevy tall deck | brian12c | Engine | 11 | 01-29-2007 09:58 AM |
| i need help with my 427 | mitch 427 | Engine | 2 | 06-22-2004 07:29 PM |
